Smart Hub 6 Variants and Performance
Fixes: 480
Re: Smart Hub 6 Variants and Performance
@Longliner wrote:
. Today's blocks are lightweight clinker or similar for insulation while most internal walls are dry lined ie plasterboard on a timber frame which stops neither wifi nor noise ... my brother's five-year-old house has no wifi problems but plenty of others!
I am currently terminating Cat5e Ethernet cabling in a friends large extension. The builder has done an excellent job with insulation by infilling the timber frame walls with aluminium faced insulation boards. This is very effective at stopping both heat and wifi getting out of rooms! Luckily I got the electrician to run Ethernet cabling to each room from a central distribution point before the plasterboard was fitted ready for me to wire up all the connectors and fit a switch.
Longliner
All Star
Fixes: 8
I'd forgotten about the Silver Skin, wasn't around last time I did any building but neither was the internet! Friends use it on outer walls only, shoestring budget so can't afford to have it inside as well. Great idea to install ducting in any new house, costs very little, as long as you remember the access points for when you want a changearound in 10 years' time.
Longliner
All Star
Fixes: 8
Hi Baldrick
Just a line to thank you again for your excellent guide to HH6 setup. I would never have sorted this without it. As you warned, my only hiccup was after step 6 (entering my PN username/login) when the SAVE button did not appear; I went back to advanced settings and the HH6 had saved the details anyway, and worked straightaway on the PCs. The iPads would not log onto wifi, until I split the signal as per instructions in posts 116-119 on previous page 8.
So how does it work? On a few days' daily TBB speedtesting, there's no difference from the PN Hub One, it's around 36Mb on my 40Mb connection. Wifi is slightly better, going by the signal bars on the iPad it's about 10% better walking around the house but still not enough to penetrate our concrete walls. The family likes the HH6 dimmable light, we had to tape over the weird blue glow from the PN One. Anyway for £15 on Gumtree I now have a first-class spare router as well as the one from PN, one's just as good as the other for our purposes. Best wishes!
PhyllisTyne
Firmware update to SG4B1B00819A on business hub this morning.
Fixes: 480
Strange, I have been on SG4B1B008198 since last August. You haven't misread A for 8?
PhyllisTyne
Definitely SG4B1B00819A
updated this morning and that is the date for the last firmware update.
I had been on the same since august that's why I thought it worthy of a post. I had assumed updates were pretty much finished for HH6
PT
PhyllisTyne
Got me concerned for a bit but log makes it look like a genuine update:
04:24:37
 09 Feb.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been closed
04:24:37
 09 Feb.
ppp1:TR69 sending SetParameterValuesResponse message
04:24:37
 09 Feb.
ppp1:TR69 receiving SetParameterValues message
04:24:36
 09 Feb.
04:24:36
 09 Feb.
04:24:35
 09 Feb.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been initiated
04:24:35
 09 Feb.
ppp1:TR69 receiving InformResponse message
04:24:34
 09 Feb.
ppp1:TR69 event found : 6 CONNECTION REQUEST
04:24:34
 09 Feb.
ppp1:TR69 event found : 4 VALUE CHANGE
04:24:33
 09 Feb.
ppp1:TR69 sending Inform message
04:24:30
 09 Feb.
04:24:30
 09 Feb.
04:24:29
 09 Feb.
04:24:27
 09 Feb.
ppp1:TR69 creating new session with ACS
04:24:24
 09 Feb.
ppp1:TR69 ConnectionRequest: processing request from ACS
04:24:24
 09 Feb.
ppp1:TR69 ConnectionRequest Failed
04:24:24
 09 Feb.
04:24:18
 09 Feb.
04:24:18
 09 Feb.
ppp1:TR69 receiving TransferCompleteResponse message
04:24:18
 09 Feb.
ppp1:TR69 sending TransferComplete message
04:24:16
 09 Feb.
04:24:16
 09 Feb.
04:24:15
 09 Feb.
ppp1:TR69 event found : M Download
04:24:15
 09 Feb.
ppp1:TR69 event found : 7 TRANSFER COMPLETE
04:24:15
 09 Feb.
04:24:14
 09 Feb.
04:24:12
 09 Feb.
04:24:12
 09 Feb.
04:24:12
 09 Feb.
04:24:11
 09 Feb.
04:24:09
 09 Feb.
04:24:08
 09 Feb.
ppp1:The NTP server used is: ntp.homehub.btopenworld.com
04:24:07
 09 Feb.
:The Modem successfully installed a firmware update
04:23:42
 09 Feb.
:The Modem is installing a firmware update
04:23:36
 09 Feb.
04:23:35
 09 Feb.
ppp1:TR69 sending DownloadResponse message
04:23:35
 09 Feb.
ppp1:TR69 receiving Download message
04:23:34
 09 Feb.
04:23:34
 09 Feb.
04:23:33
 09 Feb.
04:23:33
 09 Feb.
04:23:31
 09 Feb.
04:23:30
 09 Feb.
04:23:30
 09 Feb.
04:23:28
 09 Feb.
04:23:26
 09 Feb.
04:23:24
 09 Feb.
04:23:23
 09 Feb.
04:23:23
 09 Feb.
04:23:17
 09 Feb.
04:23:16
 09 Feb.
ppp1:TR69 sending GetParameterValuesResponse message
04:23:16
 09 Feb.
ppp1:TR69 receiving GetParameterValues message
04:23:15
 09 Feb.
04:23:15
 09 Feb.
04:23:14
 09 Feb.
04:23:14
 09 Feb.
ppp1:TR69 event found : 2 PERIODIC
04:23:13
 09 Feb.
04:23:11
 09 Feb.
04:23:11
 09 Feb.
04:23:10
 09 Feb.
04:23:07
 09 Feb.
Longliner
All Star
Fixes: 8
My 'new' HH6 installed last week is running well but the last update version SG4B1000B540 was installed in April last year. Will BT update its hub when it's being used on Plusnet?
LifeonMars
Seasoned Pro
Fixes: 12
Yes it will update automatically
Although That was the latest firmware for BT Smart Hub Version A
Type A made by Sagemcom
Type B made by Arcadyan
Longliner
All Star
Fixes: 8
Didn't even know there were two versions! Thanks again for the generous help given on this forum.
LifeonMars
Seasoned Pro
Fixes: 12
There are actually more versions if you take into account the Business Smart Hub  and the FTTP type with the Red WAN port.
http://bt.custhelp.com/app/answers/detail/a_id/10477/~/user-guides-and-manuals-for-bt-hubs
Kevin
@PhyllisTyne my business hub 6 has just updated to SG4B1B00819A too.
Have you noticed any differences or improvements?
Kevin.
Ex Plusnet, now Community Fibre.
PhyllisTyne
No, although it did drop a connection for the first time in a while yesterday but I do seem to have an odd connection. sometimes it will drop 4 times one day and then not drop again for a month! not sure i'll ever get to the bottom of it.
Kevin
When you say drop the connection, due you mean a reboot?
Mine reboots regular as clockwork every 13 days!
Kevin.
Fixes: 480
They all do this but normally every 14 days.
