remote access to router.
wiggy033
Can someone please tell me how I remotely connect to my plusnet router please?
5 REPLIES 5
Fixes: 480
Re: remote access to router.
Welcome to the forum.
I may be wrong but I don’t think you can. I understand that Plusnet can reset it for you. What precisely are you trying to do?
VileReynard
Fixes: 20
Are you wanting to remotely perform remote admin on your router?
Depending on the router it is possible - but you need to be super-careful with security.
steveocee
Opening the admin interface of your router to the wide open web is never a good idea! There will always be someone trying to access it and passwords aren't totally unbreakable.
A firewall allowing only expected IP's would be the bare minimum recommendation otherwise a VPN to administer over would be a better option which then means the HTTP port would not be exposed.
www.steveocee.co.uk
Fixes: 1,495
Moderators Note
This topic has been moved from Tech Help to My Router
LaurenB
Fixes: 131
Hi @wiggy033, I'm afraid you can only log onto your routers homepage if connected to the local network.
Please let us know if you have any further queries.
 Lauren Barry
