Setting up Hub One Router for Back to my Mac
- My Router
- Setting up Hub One Router for Back to my Mac
20-06-2017 2:39 PM
Does anyone have any advice on how I set-up the Hub One Router to allow Back to my Mac to work? At the moment I have had to disable the Firewall altogether but I obviously dont want that as a permanent solution.
Thanks in advance.
Re: Setting up Hub One Router for Back to my Mac
20-06-2017 3:51 PM
It sounds like you might need to set up port forwarding to allow this to work. There's a guide on this here: https://community.plus.net/t5/Gaming/Plusnet-Routers-and-Port-Forwarding/m-p/1307974#M17457 -Chris
Chris Parr Plusnet Staff |
21-06-2017 9:41 PM
Having had a quick read of Apple's "Back To My Mac" documentation I'm not over optimistic about getting the Hub One to work in this way, particularly in any way I would consider secure.
- My Router
