Setting up Hub One Router for Back to my Mac
simonjudd
Does anyone have any advice on how I set-up the Hub One Router to allow Back to my Mac to work?  At the moment I have had to disable the Firewall altogether but I obviously dont want that as a permanent solution.
Thanks in advance.
Smiley
2 REPLIES 2
Chris
Legend
Fixes: 169
Re: Setting up Hub One Router for Back to my Mac
It sounds like you might need to set up port forwarding to allow this to work. There's a guide on this here: https://community.plus.net/t5/Gaming/Plusnet-Routers-and-Port-Forwarding/m-p/1307974#M17457 -Chris
markhawkin
Fixes: 12
@simonjudd
Having had a quick read of Apple's "Back To My Mac" documentation I'm not over optimistic about getting the Hub One to work in this way, particularly in any way I would consider secure.
