Setting up 2.4ghz for smart plugs
Meatballs_100
Hello all
I have just set up my full fibre however I now need my smart plugs to work and they only work on 2.4ghz. I can't see where to split the 2.4 and 5 and wondered who can help please? the plugs are not picking up the wifi while in the current mode.
Thanks in advance.
4 REPLIES 4
Marksfish
All Star
Fixes: 5
Re: Setting up 2.4ghz for smart plugs
You can't split the frequencies if the PN router. one of its downfalls.. I think you can turn off 5ghs, then connect your slower items, then turn it back on again.
Fixes: 392
@Meatballs_100 You need to temporarily disable the 5ghz channel whilst setting up the smart plugs - see attached image - and then re-enable it once they are working.
Meatballs_100
Thank you. I thought that might be the case. I will do them all at the weekend.
Fixes: 1,495
Moderators Note
This topic has been moved from Full Fibre to My Router.
