Sagemcom ROUTER 2704N PLUSNET firmware upgrade
bobpullen
Fixes: 331
Re: Sagemcom ROUTER 2704N PLUSNET firmware upgrade
Hi Grant,
Your router is in sync at 1.2mbps, which is in-line with your estimate:-
The highest observed throughput I'd expect on an ADSL line is about 1.3mbps.
So in short: yes, it's normal.
An upgrade to a Fibre product would likely see your upload speed increase to 19mbps or so.
grantmacdo
Thanks for clearing that up Bob, much appreciated. I'll have a think about upgrading.
Many thanks
Grant
