Sagemcom ROUTER 2704N PLUSNET firmware upgrade
esgesp
Dear team,
I have had this router, Sagemcom model ROUTER 2704N PLUSNET for about 8 months now and have not had major issues until recently where my router is behaving unstable and takes long to load the config pages.
I have restored to factory settings and rebooted with same results.
Could someone please push the latest firmware to it?
Firmware version appears as,
7.275.11_F2704N_Plusnet
and boot loader,
7.275.11
This can be done anytime.
Many thanks.
Kind regards,
31 REPLIES 31
asifh
Re: Sagemcom ROUTER 2704N PLUSNET firmware upgrade
https://community.plus.net/t5/user/viewprofilepage/user-id/14
I'm having similar issues and the access control keeps losing the config.  I am on
7.275.6_F2704N_Plusnet
which seems very old
bobpullen
Fixes: 331
@esgesp, that's the latest version we've shipped with.
@asifh, yours is old. I'll look at pushing an update when I'm next in the office. Give me a nudge in a few days if you've not heard from me.
esgesp
Thanks @bobpullen for coming back.
If I am already on the latest available firmware I guess I need to look at something else because the router is like doing dodgy things more and more often. Configuration pages are not displayed properly when clicked, I need to refresh them continuously and sometimes I haven't got a connection at all despite all lights being on and stable.
Thank you anyway.
I will keep monitoring.
asifh
Thanks @bobpullen
esgesp
Hi @bobpullen and apologies for pestering you again.
I just realised you said this firmware is the latest version you've shipped with however I wonder if Sagemcom may have a newer one and this could be packaged for PlusNet. I got this router since March last year and that is why I am saying, there may have been newer versions since then.
Can you please let me know on this?
Kind regards,
bobpullen
Fixes: 331
@esgesp, there is a build that's a 'dot version' higher, however it doesn't incorporate anything I think will help with the issues you're reporting. I'll push the build to you when I do the same for @asifh.
esgesp
Thanks @bobpullen for this.
I am looking forward to it. Please let me know if I need to reboot my router after patching or any other action from my side afterwards.
Many thanks.
bobpullen
Fixes: 331
@asifh, yours has been upgraded. The router will have rebooted to apply the update.
@esgesp, your router seems to be a bit sluggish accepting the upgrade instruction. Might be an idea to reboot the device and see if that helps.
esgesp
Hi @bobpullen,
I will be at home in about half an hour and I will reboot it for you.
I will let you know here.
Thank you.
Kind regards,
esgesp
Hi @bobpullen,
I have just rebooted my router.
Please let me know if you can push the firmware upgrade now.
Many thanks.
Kind regards,
bobpullen
Fixes: 331
@esgesp, thanks. All done Smiley
esgesp
Thanks @bobpullen,
I have now checked and got version 7.275.12_F2704N_Plusnet.
Many thanks for this.
Boot loader still appears as 7.275.11, is that expected?
Kind regards,
bobpullen
Fixes: 331
Yes, I think that's expected. As alluded to earlier, the difference between this and the earlier firmware is minimal.
asifh
Thanks @bobpullen , my router now reports
