Sagemcom ROUTER 2704N PLUSNET firmware upgrade
Farnzie
Re: Sagemcom ROUTER 2704N PLUSNET firmware upgrade
Hi @bobpullen  my router has the firmware below, how do I upgrade it?
7.275.6_F2704N_Plusnet
MatthewWheeler
Fixes: 503
Thanks for getting in touch @Farnzie.
I've requested this for you and we'll get that updated for you as soon as possible.
Let us know if there's anything else we can help with
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
bobpullen
Fixes: 330
@Farnzie, your router has just rebooted to apply the latest update.
Farnzie
thanks bob, just checked & it's on the latest Smiley
Beyhive
Fixes: 44
Good to hear that @Farnzie,
Let us know if there is anything else you would like us to help with please.
 Faris
gavinevans146
Can you push through a firmware update please?
MatthewWheeler
Fixes: 503
Thanks for getting in touch @gavinevans146 and apologies for the delayed response.
Before we arrange this for you can you confirm the current firmware version on your router?
sallinski
Hi Bob,
I am having to work from home currently and would like to make sure that my modem has the latest firmware version please.
Here is my version:
3 - Firmware version:     7.273.1_F2704N_Plusnet
I presume you identify me by username.
Your help would be much appreciated. Thanks in advance.
s.
bobpullen
Fixes: 330
@sallinski, I understand this was actioned earlier for you.
Lysen
Same issue. Unresponsive. Impossible to use the internet, let alone the LAN.
bobpullen
Fixes: 330
@Lysen doesn't sound like your isue is related to this thread reading some of your other posts? Huh
Anyway, I've pushed the latest available firmware to your device. It will have rebooted to apply the update.
Lysen
Thanks for sending the update this way @bobpullen.
The instability and long time to load the GUI is the same deal i'm getting, but the cause is anyone's guess. Since there's no firmware available online, i figured it'd be nice to at least try to latest version and see how it fares.
grantmacdo
I have been having slight issues with my upload speed. I have read online that updatung router firmware might be a quick fix.
My router details are
1 - Product name:Plusnet Router
2 - Serial number:N7180061B004369
3 - Firmware version:7.275.6_F2704N_Plusnet
Any help or advice would be much appreciated.
Grant
bobpullen
Fixes: 330
@grantmacdo not sure it's going to help with your issue, however I've pushed a more recent software version to your router. It will have rebooted to apply the update.
grantmacdo
Thanks Bob, much appreciated.
As you suggested didn't make any difference. I'm currently getting a download speed of around 20 Mbps but and upload of speed of around 1 Mbps.
Is that normal?
Thanks again,
Grant
