Router and laptop
Fixes: 585
Re: Router and laptop
My thinking is if the laptop is seven years old then I would perhaps recommend try changing the Wireless Mode from 1 to 2 or 3 to see if that helps
@Dan_the_Van that was going to be my next suggestion if the 5ghz disable had no effect
SteveDee
Thank you for this but struggling to find this on Windows 10.
Fixes: 585
That would be because it's nothing to do with Windows! It's a setting in the router ...
SteveDee
Thank you. Will have a look tomorrow and report back
It is found here
Here you can turn off 5GHz and/or experiment with the Wireless Mode setting
HTH
SteveDee
Brilliant, thank you!
SteveDee
Sincere thanks to all who replied. Changing the setting to 2 did the trick. Very grateful for your help!
