Router Type and Firmware
- My Router
- Router Type and Firmware
27-03-2020 1:39 PM
Hopefully someone can give me a couple of pieces of information. Have been with PN for a few years and about to renew subscription. I have a old Hub Zero router and trying to make the best of having been bypassed by the information super highway.
1. What router does PN supply for ADSL connections these days.
2.What is the lastest firmware version for Hub Zero and Hub One.
Would be most grateful for any guidance please.
Archer.
Re: Router Type and Firmware
27-03-2020 1:49 PM
Moderators Note
This topic has been moved from ADSL Broadband to My Router
28-03-2020 2:57 PM
It's still the old Hub Zero I'm afraid
Hub Zero: 7.275.11_F2704N_Plusnet
Hub One: 4.7.5.1.83.8.263
28-03-2020 5:30 PM
Thanks for the info.
Do you have any recomendations for a router with a bit more wifi range?
Archer.
29-03-2020 11:47 AM
I would replace your Hub Zero with a BT Smarthub 6. These are really cheap off auction sites such as EBay and are far superior in every respect in terms of WiFi performance. They work on both ADSL and Fibre services, Setting instructions are here: https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
30-03-2020 6:06 PM
I found a long forgotten BT HH4 in the loft so gave it a try. Changed the User name and bingo!
Seems to perform better than PN router.
Makes me wonder why PN bother with own routers as all part of BT. I guess they have there reasons.
Thanks for the guidance. Problem solved!
