Router Firmware
MJJ1
Router Firmware
Can anyone tell me what the latest firmware version is for the Plusnet Hub 1 and how often updated versions tend to be issued?
3 REPLIES 3
Fixes: 385
Re: Router Firmware
@MJJ1  Latest - and probably final - is : 4.7.5.1.83.8.289.1.3
Fixes: 479
Re: Router Firmware
@MJJ1
The latest versions are in the post pinned at the top of this Router board. They are updated when there is an update.to release.
Moderator's note:
Thread moved from Broadband to My Router
Re: Router Firmware
@MJJ1  if you wanted to make the most of your Plusnet Hub 1,
you could install  OpenWRT  firmware instead, and vastly improve your router's capabilities !
See forum topic - Running OpenWRT on the Plusnet Hub One
It doesn't look too difficult to achieve, just needing a little patience and careful following of the instructions.
