Returning customer - greetings & BT HH5 question
mrtullyhubbert
Hi all
Its been some years now but i was previously a happy PlusNet ADSL customer. I only moved to BT when FTTC became available and PN weren't able to offer that at the time. Mostly due to cost/usage I'm now returning to PlusNet on the 14th July (Fingers crossed)
I currently have a FTTC 38mb connection and use a BT Home Hub 5 plugged into a filtered faceplate. I'm changing to the same connection type/speed with PlusNet.
Today I received my PN hub one. I'm assuming its a white home hub 5 with pink feet and some firmware changes?
I'd much rather keep using my black HH5, if I don't change the SSID this would have the added benefit of not having change the wifi key in any of my/family/friends devices. So I just need to change the broadband username/password to myplusnetusername@plusdsl.net/my PN account password in the HH5 advanced settings. Can someone confirm that this is the case?
Thanks in anticipation
5 REPLIES 5
bobpullen
Fixes: 316
Re: Returning customer - greetings & BT HH5 question
Yep, that should do the trick.
mrtullyhubbert
Thanks Bob, great to see a familiar name again Smiley
You were providing me with advice back in the days when usenet was mainstream! lol
Mustrum
Fixes: 77
Hopefully you won't be disappointed with the 2Mbps uploads speed after being used to 10Mbps with BT.
mrtullyhubbert
I did notice this before applying to transfer but without doing much/any research decided that with my use case it 'prob' won't affect me.
I surf with a PC & browser / mobile, stream some TV/video services and the only upload I think I do is when my phone backs up pics/vids on WiFi? A bit late to ask but how might this affect me?
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
Fixes: 1,601
Welcome back! (You probably won't remember me, I've only been here a few years)
As a point of reference, with a 2mbps upload speed you should be able to upload about 900MB per hour which (in my opinion) is a hefty amount for normal usage, but I guess it depends how big the files are you're uploading.
