Problem with broadband signal
Michaelw89
Has anybody had problems with their broadband connection over the last 10-12 hours?
My hub device is connected with the blue light displayed, but currently I'm 'not connected to the internet' according to one of the devices I use. This is the same messaging I receive when using other devices. I have turned the hub off and on again, but so far no success.
I'm currently using the data of my mobile phone device to access the internet. Any suggestions would be welcome.
Many thanks.
7 REPLIES 7
Fixes: 392
Re: Problem with broadband signal
Which device is displaying this message? Are other devices still showing as connected, and working?
Michaelw89
Hi John,
The connection status on my Amazon Fire TV device is displaying 'Connected to Wi-Fi'; 'Not connected to the internet'. All my other devices are displaying a similar message (2 mobile phones; 2 laptop computers; tablet device; smart speaker device)
Fixes: 392
Can you post the Help Desk from your hub please - picture below will show you where it is:
Fixes: 1,665
Hi @Michaelw89
I'm sorry to see you're having issues with your connection.
I can see your router was trying to connect using the wrong password but that seemed to have been resolved when you rang us not long ago although your broadband's since not been connected to the internet again.
Line tests are showing your router's not turned on, can you confirm it is?
Fixes: 392
Be good if I knew the OP was using alternative avenues.
Michaelw89
Hi Gandalf,
Thanks for your reply.
I can confirm the reason for me being unable to connect to the internet was because I was trying to connect using the wrong password. As I going the process of re-establishing a new password, an error message informed me that as the system made more than 100 attempts it was not able to proceed, therefore I turned off the power to the hub for approx.. 1 hour. The advisor rang back and was able to continue re-connecting me to the internet by creating a new password. This was successful and I am now able to access the internet.
Many thanks,
michaelw89
Fixes: 1,665
Thanks for getting back to me @Michaelw89
I'm glad to see the adviser helped get your broadband sorted for you Smiley
Let us know if there's anything else you'd need help with
