Possible privacy / security problem after changing to a non plusnet router
Re: Possible privacy / security problem after changing to a non plusnet router
@Star-Light100
with a Plus Net supplied Hub the management system will assign your username to the Hub when it connects, so there is no user action required.
When you use a 3rd party device then you have to configure it yourself.
I suggest you plug your Plus Net Hub back in and see if you get the same results.
It is high unlikely the TP-Link device is causing this issue.
Dan
Star-Light100
Ok I’ve reconnected my hub one and I’m still seeing my user name but with plus.com instead of plusdsl.net at the end. So I’m a bit confused now how I can get this fixed.
Fixes: 391
@Star-Light100 How long have you been a Plusnet customer? I still suspect you have a static IP - what are the first 3 octets?
Star-Light100
Hi, over 18 months now. The first part of my IP address 192. . If that’s what you wanted to know?
Fixes: 391
OK. That 192 sounds like the start of your routers address to me - AIUI that is part of a reserved range for routers/hubs &c.
Which Plusnet hub have you got?
Star-Light100
It’s a hub one
Fixes: 391
OK, in that case, can you send me a screen-shot of the Help Desk page with nothing obscured via PM, please.
@jab1
the help desk page does not show the broadband IP address, you need advanced settings >broadband >internet
@Star-Light100  you can find your broadband IP address here https://whatismyipaddress.com/
Fixes: 391
Sorry Dan - never having had the Hub1, I forget that it doesn't - I'll try and remember. 😉
@Star-Light100
you can also check in the members centre to see if you have a static IP Address.
From the Members Centre Home from the right of Home select Add-Ons, scroll down and set what is under Static IP
There should be a choice Add this bolt-on or Remove remove this bolt-on. I would expect to see Remove this bolt-on
This issue needs looking at by Help Desk staff as there is nothing else can be done here.
Dan
Star-Light100
Hi guys, thanks for your help with this matter. I’ve just been on the phone to plusnet. They say I don’t have a static IP address. They also said they are resetting my IP address. And that should fix the problem. So far nothing has changed
You have to reboot the Hub One or TP-Link for the change to take.
Star-Light100
Just restarted my new router and still showing my username as before ☹️. Will give it a few hours and see if anything changes
RPMozley
Seasoned Pro
Fixes: 18
If a reverse DNS change has been made to the IP address, it can take up to 48 hours completely propagate.
That's RPM to you!!
Fixes: 251
There does seem to be a degree of confusion herein.  In summary...
  1. A Plusnet supplied router will generally self configure the user account details
  2. For a third party router the user has to explicitly enter the user account details
  3. Therefore either router contains the same details [email protected]
  4. Irrespective of whatever router a user uses, the IP addressed assigned will be the same for that connection
    1. A static IP address if the account has one
    2. A dynamic one if the account does not have a static IP address
  5. GRC Shields up performs a rDNS lookup on the current IP address - the default rDNS entry for a Plusnet IP address is username.plus.com
This has nothing to do with which router you use or any suspicion about the security of the router - this information is NOT coming from the router.
