Possible privacy / security problem after changing to a non plusnet router
Fixes: 146
Re: Possible privacy / security problem after changing to a non plusnet router
@Star-Light100
with a Plus Net supplied Hub the management system will assign your username to the Hub when it connects, so there is no user action required.
When you use a 3rd party device then you have to configure it yourself.
I suggest you plug your Plus Net Hub back in and see if you get the same results.
It is high unlikely the TP-Link device is causing this issue.
Dan
Star-Light100
Ok I’ve reconnected my hub one and I’m still seeing my user name but with plus.com instead of plusdsl.net at the end. So I’m a bit confused now how I can get this fixed.
Fixes: 380
@Star-Light100 How long have you been a Plusnet customer? I still suspect you have a static IP - what are the first 3 octets?
Star-Light100
Hi, over 18 months now. The first part of my IP address 192. . If that’s what you wanted to know?
Fixes: 380
OK. That 192 sounds like the start of your routers address to me - AIUI that is part of a reserved range for routers/hubs &c.
Which Plusnet hub have you got?
Star-Light100
It’s a hub one
Fixes: 380
OK, in that case, can you send me a screen-shot of the Help Desk page with nothing obscured via PM, please.
Fixes: 146
@jab1
the help desk page does not show the broadband IP address, you need advanced settings >broadband >internet
@Star-Light100  you can find your broadband IP address here https://whatismyipaddress.com/
Fixes: 380
Sorry Dan - never having had the Hub1, I forget that it doesn't - I'll try and remember. 😉
Fixes: 146
@Star-Light100
you can also check in the members centre to see if you have a static IP Address.
From the Members Centre Home from the right of Home select Add-Ons, scroll down and set what is under Static IP
There should be a choice Add this bolt-on or Remove remove this bolt-on. I would expect to see Remove this bolt-on
This issue needs looking at by Help Desk staff as there is nothing else can be done here.
Dan
Star-Light100
Hi guys, thanks for your help with this matter. I’ve just been on the phone to plusnet. They say I don’t have a static IP address. They also said they are resetting my IP address. And that should fix the problem. So far nothing has changed
Fixes: 146
You have to reboot the Hub One or TP-Link for the change to take.
Star-Light100
Just restarted my new router and still showing my username as before ☹️. Will give it a few hours and see if anything changes
RPMozley
Seasoned Pro
Fixes: 16
If a reverse DNS change has been made to the IP address, it can take up to 48 hours completely propagate.
That's RPM to you!!
Fixes: 244
There does seem to be a degree of confusion herein.  In summary...
  1. A Plusnet supplied router will generally self configure the user account details
  2. For a third party router the user has to explicitly enter the user account details
  3. Therefore either router contains the same details [email protected]
  4. Irrespective of whatever router a user uses, the IP addressed assigned will be the same for that connection
    1. A static IP address if the account has one
    2. A dynamic one if the account does not have a static IP address
  5. GRC Shields up performs a rDNS lookup on the current IP address - the default rDNS entry for a Plusnet IP address is username.plus.com
This has nothing to do with which router you use or any suspicion about the security of the router - this information is NOT coming from the router.
