Plusnet supplied router playing up
cjags
Fixes: 4
One of my referees has a problem with thier plusnet router.
Tthe internet drops, the blue light goes green, then starts flashing, then the blue light reappears as does the internet.  What does this mean?
8 REPLIES 8
Fixes: 1,495
Re: Plusnet supplied router playing up
Moderators Note
This topic has been moved from Broadband to My Router
Fixes: 1,495
If it's green and not orange, then it sounds like the router is rebooting.
Can you get the logs?
cjags
Fixes: 4
No I can't, the router is 150 miles away.
The landline is working but the internet keeps dropping in and out and the plusnet router goes through the green light, flashing light, blue light routine at the same time.
Router isn't that old but could it be faulty?
cjags
Fixes: 4
Just been told that the flashing light is ornage.
Is there an online manual anywhere.
Fixes: 145
@cjags
Click Help on right corner of the Hub One home page that is the user guide, the light meanings are towards the end.
HTH
LaurenB
Fixes: 131
Hiya @cjags, thanks for getting in touch. I'm sorry to hear of the issues that they're having with the service.
Can you send me a PM over with the account username and I can then take a further look at this?
(to send a PM, click on my name and then to the right, there will be a grey button to 'send private message' and in the message please include a link to this thread)<br/>
 Lauren Barry
cjags
Fixes: 4
Hi Lauren.
I did the HELP txt message broadband fault thing and Plusnet reset their end and my referee switched everything off and back on and things have been stable since.
LaurenB
Fixes: 131
Ah OK fab, just get back to me if you need any further support at all.
 Lauren Barry
