Plusnet Hub One | 5GHZ
smallblueplanet
Re: Plusnet Hub One | 5GHZ
Thanks @adam945 , appreciate your helping out. We are out in the countryside and it gets a bit poor at times. Over the years I've had new master faceplates, new wiring, new connection box on the eaves, think they might even have rewired from the wooden pole about 30m (ish) away. Cheesy It's never 100% and we mostly accept that. But I had gotten used to the Sky Q router and forgotten how the Plusnet one could be iffy. I'm not sure of the correct technical terminology. Wink Last night was a bit poor weather wise and we had 3 or 4 power outages.
So thanks again for stepping in. Smiley ps I hope it's me you're helping as I've just realised this is an old community forum login! Cheesy My current username is ar........h..4
LaurenB
Fixes: 131
Hiya @smallblueplanet, it looks like Adam has took action on the right one for you.
I am sorry for the issues with your service and hope the steps taken help out with this. Let us know how it goes!
 Lauren Barry
Longliner
All Star
Fixes: 8
Why not treat yourself to a BT HH6. will cost you all of £5-£15 on auction sites?  For trifling cost, and using Baldrick's excellent setup guide on this forum, many of us enjoy great performance with none of the Hub One issues.
smallblueplanet
Thanks @Longliner could you provide me with a link to Baldrick's setup guide please?
Longliner
All Star
Fixes: 8
Longliner
All Star
Fixes: 8
@smallblueplanet
I should have suggested that you post here if you encounter any problems, the man himself has all the answers as you'll see from the 55 pages on his thread!
