Plusnet 2 Router won’t connect to Hive Hub
- My Router
- Re: Plusnet 2 Router won’t connect to Hive Hub
- « Previous
- 1
- 2
- Next »
06-11-2022 9:33 AM
I am having the same problem. Green light flashes on my hive hub but won’t change to Amber. It’s not pairing. Help!!!
Message 16 of 18
(1,539 Views)
06-11-2022 12:12 PM
Hi, my problem was down to faulty ethernet ports on the router. Check these are working with another device, then if not plusnet should hopefully replace router. Solved the hive hub issue. Good luck.
06-11-2022 1:34 PM
Thanks! I will contact them and get a new router then
Message 18 of 18
(1,502 Views)
- « Previous
- 1
- 2
- Next »
- My Router
