PlusNet Hub one crashing
AndyD1
Re: PlusNet Hub one crashing
BT are now here. He’s found an interference fault. He’s just trying to find where it’s at.
Fixes: 1,601
Sounds promising! Keep us posted on this
AndyD1
Right.
The engineer is happy with the line. He says he’s found and fixed the fault. Tested my line and all looks good. I’ve just done a speed test and get 49.11Mbps.
I’ll keep an eye on it for a few days regarding dropouts and speed.
Fixes: 1,601
Cool. Fingers crossed it remains stable now
AndyD1
The hub went off last night between 8-9pm. So far it’s remained connected. Speed now is 46.95Mbps.
Fixes: 1,601
Thanks for the update Andy. Keep us posted
AndyD1
Hello.
Router went off about 2am. Don’t know if it was just the once. Was doing so well.
Speed is still around 45Mbps.
Going to keep an aye on it over the next week.
AndyD1
Router went off around 7 this morning again. Speed is now 40.18Mbps.
AndyD1
Speed now into the high 30’s.
Fixes: 1,601
Hi Andy. I'd recommend continuing to monitor this for a week or so as this will give us a bigger picture of what's happening. Your router is still getting a speed of 48.8mbps and there's no issues detected and the drops seem minimal:
AndyD1
Will do.
AndyD1
Hub has been ok since Friday morning but download speed has never been in to 40s since.
Seams to be anywhere from 35 to 38Mbps.
I’m using the BT wholesale test site on a wired connection.
AndyD1
Router went off about half 2 this morning.
Speed is 41.08.
Fixes: 1,601
Thanks for getting back to us @AndyD1
I'm sorry to see your speeds are starting to decline although our testing is still showing your sync speed up at 55mbps. We can see the drops you've had though which would likely explain your lower download speed/throughput.
I'd recommend continue monitoring this and if the drops continue, we'll need to arrange another engineer visit.
Let us know how you get on.
AndyD1
Ok no problem. Router dropped at about 9 this morning.
