PN Hub one Port forwarding help required
FIXED- Subscribe to RSS Feed
- My Router
- Re: PN Hub one Port forwarding help required
18-06-2020 10:54 AM
I'm trying to set up port forwarding for a pi showing on my hub as piaware.
Referring to attachment Hub-1 it shows piaware as being on ip address 192.168.1.79 (this is the correct address ) but when I set up port forwarding and select device piaware it show ip address 192.168.1.76 (see attachment Hub-2)
How can I correct this - the device is on and operating ok but the port forwarding isn't working
Paul
Fixed! Go to the fix.
18-06-2020 2:57 PM - edited 18-06-2020 3:09 PM
Hi @paulgul
A power off the modem/router might clear the IP address confusion as I have had the same issue recently with IP address showing up incorrect .99 when it should have been .250
Edit
I have a Hub One and assign hostname to each port forward rule rather than an IP address.MAC address does not appear on my device.
Dan.
19-06-2020 5:56 PM
Thanks Dan,
Yes, that has cured the problem - port forwarding working now
Paul
- My Router
