New router disconnecting
andrew3498
I have just connected my new Plusnet Hub 2 (previous Plusnet router was working fine, but decided to upgrade to the newer one) but it keeps disconnecting randomly every few minutes with an orange light on the router. Eventually it returns to blue and works again. Anybody else experienced this? I am trying to give it a bit of time to hopefully settle down, but if not, the old router will be going back in.
Regards
Andrew
10 REPLIES 10
Fixes: 388
Re: New router disconnecting
Log in to the hub by putting 192.168.1.254 in the address field of your web browser.
On the Home page under My Services you will see the current Broadband Username. If it’s [email protected] then it has not been configured by PlusNet authorisation systems.
First try a factory reset of the hub by pushing a paperclip or similar into the reset hole and hold the switch closed for at least 20 seconds, the LED should turn green and then release
Leave the Hub Two for around 10 minutes and check Home page for correct Broadband Username <your username>@plusdsl.net
If it still shows [email protected] follow these steps.
Navigate from the Home page to >Advanced settings (you will be required to enter the Hub One admin password this found on bottom of the Hub or card with WiFi password).
Click on Continue to Advanced Settings then >Broadband >Internet
This page details your broadband Internet Connection Configuration.
Click on disconnect, if this does not work it may be necessary to remove the DSL cable.
Enter your correct username <your username>@plusdsl.net and password.
Plug in DSL cable (if removed) and click on Connect
Check your Hub One has logged on to the correct Broadband Username
Strat
Fixes: 565
Moderators Note
This topic has been moved from Fibre Broadband to My Router.
andrew3498
Thanks for your reply. The username is our username followed by @plusdsl.net . I guess I will have to see how it is tomorrow. If it still keeps disconnecting, I will return to the old router, which is a real shame, but I work from home and need reliable service
Fixes: 388
@andrew3498 Very strange - the username/password error, which you don't apparently have, is the usual culprit for this issue. To be honest, I personally  can't think of other reasons, but maybe other Community members will have a better idea. I have no experience of this Hub as I am no longer with PN, but I would persevere as it is a definite improvement when it works correctly.
@MisterW  @Baldrick1  - any ideas
Fixes: 585
Sight of the helpdesk tab and event log would be useful
Fixes: 388
@MisterW True - I was a bit tired when I posted last night, and forgot the obvious. Embarrassed
To help find the required info:-
For the Hub One -
Navigate from the Home Screen to Troubleshooting > Helpdesk or >Event Log
For the Hub Two -
Navigate from the Home Screen to Advanced Settings > Technical Log > Information or >Event Log
LaurenB
Fixes: 131
Hiya @andrew3498, thanks for getting in touch. I'm really sorry that you've been having some issues with the Hub Two! I can see a number of drops yesterday, though things look to have stabilised since. Have you still got it connected or did you change back to the Hub One?
I've had a test of the line and this hasn't highlighted any issues.
 Lauren Barry
andrew3498
Hi Lauren
It has been more stable the past couple of days, so I am hoping it was just bedding in. Does it have to install updates when it is new that can cause connection to drop? I'm just guessing. Either way, I will monitor it for another week and hope it continues to be stable. On the plus side, my wireless range in the house is much better with the Hub 2.
Andrew
Fixes: 1,664
Hi Andrew,
Cheers for getting back to us. I'm glad to see your connection's a lot more stable now and WiFi range improved!
The router should come with the latest firmware, but any updates should go through in the early hours of a morning.
I'd agree and keep an eye on it, but let us know if you have further issues or there's anything else you'd need help with.
