New Hub2 — can I obtain one?
lighteningshado
Re: New Hub2 — can I obtain one?
Thank you. That is a different number to the one I was given to call on.
I will give it a try tomorrow
Fixes: 1,662
No problem @lighteningshado
0800 013 2632 is the direct number for Customer Options who are our Sales & Retentions folk.
When I say direct though, there's still a switchboard/IVR but the option you'd choose is 1.
If you had called our main number 0800 432 0200 I believe the options to get through to that same team is 4 then 1.
lighteningshado
Thank you for that.
I've just called that number and everything is now sorted out. I will be getting a new hub after Christmas : )
Anoush
Aspiring Hero
Fixes: 139
Excellent! Thumbs_Up
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
philiplgbennett
I recontracted my Fibre Broadband as well in Dec for another two years and wasn't offered a new Hub Two. I've been a PlusNet customer for about 15 years now. Would it be possible for me to get one as well ?
IngeJones
Does the Hub2 have the same problem as the Hub1, randomly not showing various connected devices?  It's been a real nuisance.
southerner
Can you get a Hub 2 if your Hub 1 has a fault?
I was looking at BT Smarthubs on Ebay but recall reading they are now locked to BT?
Fixes: 1,662
We would generally replace a Hub One like for like.
At the moment, we're generally only sending a Hub Two out under the following scenarios:
  • Sign up as a new customer
  • Upgrade your service either online or over the phone, for example, standard broadband to fibre, or fibre to fibre extra
  • Renew your contract & discuss the possibility with our Customer Options Team on 0800 013 2632
southerner
Does anyone know the newest BT hub that still works with Plusnet?
Been on Fibre Extra for a while so nothing to upgrade to. Don't really want to take out a new contract until I know whether there will be a Plusnet FTTP offering.
Fixes: 479
Well the Smarthub 2 does. I doubt you'll find anything newer going at a bargain price for a fair while, so if you want something newer I suggest that you look at a third party maunfacturer.
briston
It was reported in the technical press that Plusnet are going to offer FTTP later in the year
198kHz
Fixes: 42
It was reported last year too.  😉
BT technician (Retired)
