Slow broadband
79Artyblue1
Slow broadband
When I take my laptop upstairs in my house I get a weak signal, when I am downstairs near my router it is a medium signal have never had a fast signal. Can anyone help me?
6 REPLIES 6
Fixes: 389
Re: Slow broadband
Welcome to the forums, @79Artyblue1 How old is your laptop? and which Hub do you have? What do you mean by weak/medium/fast signal?
Fixes: 1,665
Re: Slow broadband
Thanks for your post @79Artyblue1
I'm really sorry to see you're having Wi-Fi signal issues around your home.
I'd recommend having a go at some troubleshooting steps explained Here but feel free to get back to us with how it goes and we'll be happy to help further if you're still experiencing problems.
79Artyblue1
Re: Slow broadband
Actually it is a Acer Chromebook 2 years old, when I click on the the broadband icon it tells if it is a medium signal or weak one
Fixes: 389
Re: Slow broadband
Thanks for that info, @79Artyblue1 , so it should be 5GhZ capable. Which modem/router do you have? and have you considered @Gandalf 's advice?
Do you actually see any deterioration in performance?
Mav
Fixes: 518
Re: Slow broadband
Moderator's note(s):
Thread moved from ADSL Broadband to My Router.
Forum Moderator and Customer
Mav
Fixes: 518
Re: Slow broadband
Moderator's note by Mike (Mav): The fix removed from my post.
