My virus scan software detected a vulnerabilty in my plusnet router
AngieB4
Re: My virus scan software detected a vulnerabilty in my plusnet router
Thanks for the helpful info.
Much appreciated.
the Firmware version of our Router is:
Firmware version:
v0.10.00.04201-PN
We turn our Hub 2 router off at night.
I'm wondering if we may have missed a firmware update?
Many thanks.
AngieB4
Fixes: 383
@AngieB4 You have the current firmware.
Can I ask why you turn the router off at night? - they are designed to be left on 24/7, and constantly turning them on/off  can (a) unnecessarily stresses he components/shorten their life and (b) does mean you can miss updates, as they are usually pushed out in the small hours.
AngieB4
Hi.
Unfortunately we didn't realize this.
It's in our room and the light is bright.
However,we will leave it on in future.
Do you know if
Firmware version:
v0.10.00.04201-PN is the latest version, or do I nned to ask a moderator to update the firmware for us?
Many thanks.
AngieB4
Fixes: 383
You could always put a sheet of cardboard in front of it at night. 😀
You have the latest firmware.
AngieB4
Thanks John.
We will try that.
As we have the latest firmware, I'm assuming the avg warning is not a concern.
Many thanks for your help.
AngieB4
Fixes: 580
You can dim the light or even turn it off at night https://www.plus.net/content/dam/plusnet/documents/a11y-transcripts/controlling-your-hub-lights.pdf
Fixes: 383
The AVG warning is, to be polite, a load of bull.
Fixes: 383
I'd forgotten that little trick, @MisterW 😁
AngieB4
Thanks very much.
Have done that now.
AngieB4
Mav
Fixes: 518
@AngieB4
In my view I don't see a need for any AV software (paid for or free) to be added to an Android device as long as you keep the OS and apps up to date and only download apps from Google Play.
I have used Samsung Galaxy phones and tablets for years with my S23 currently running Android 16 and One UI 8. In all these yesrs I have never had a virus or other malware-based issue.
Programs like AVG just slow things down.
Forum Moderator and Customer
