VPN port forwarding outgoing blocked
johnmcdtf
I have wireguard setup on a home server but it is blocked from sending outgoing packets by the router (Plusnet Hub Two)
If I start a VPN on the LAN, this works.  i.e. set the VPN address to the server LAN address and start a session, connects ok.
If I use a port forward rule on the router then the VPN does not connect.
does not work even with router firewall disabled
I'm a new customer to Plusnet, from BT.  So with a v similar router what worked on BT does not work on plusnet.
The wireguard server is connected via LAN (not wifi) directly to the router.  A static IP is assigned.
port 51820 is the configured VPN port and is set to port forward
checks I've done are:
router log confirms port is opened:
FWL Port Forward Server(192.168.1.101) UDP 51820 accepted a new connection from 00.00.00.00 (hidden address)
I can see the wireguard log as well:
Receiving handshake initiation from peer 1 (00.00.00.00:21980)
Sending handshake response to peer 1 (00.00.00.00:21980)
No route to 00.00.00.00:21980, error -101
any other info to help resolve this?
I'll continue to investigate and will comment back if resolved
Tags (1)
16 REPLIES 16
Fixes: 585
Re: VPN port forwarding outgoing blocked
This https://bbs.archlinux.org/viewtopic.php?id=300988 might be worth a read
johnmcdtf
thought to delete the existing VPN tunnels and recreate the tunnels and clients from scratch.
So two tunnels created, one for use on the LAN side, and another for use via WAN and port forwarding.  With a new client for each so that I can test either from LAN or WAN from a mobile phone.
Sadly, same situation.
johnmcdtf
thanks, I've had a read but have to admit that I'm not familiar with routing tables so struggling to understand that thread.
Fixes: 585
The solution in that thread was to change the Mtu in the lifeguard config
johnmcdtf
OK, understand now.  I made a quick change to 1200, but still no joy.
I expect it's a routing problem as the tunnel isn't handshaking.
Fixes: 251
@MisterW
AIUI no out bound posts are blocked … or need to be forwarded.  However, might inbound port mapping be required for the handshaking?
As a new customer I guess we can rule out the account connection based firewall configuration.
Fixes: 585
@Townman
Correct
From @johnmcdtf s posts above, he appears to have the required port forward in place. I use Wireguard myself and all that's required is to port forward UDP on the correct port to the wireguard server IP. In my case I dont use a Hub 2 but that doesnt appear to be the problem, the log posted above shows the port forward is active.
@johnmcdtf
To confirm you are using a wireguard server, client or both server and client?
Although on the same CP I have moved my VPN server openVPN and Wireguard across three routers, provided the IP Address network is retained (192.168.1.0/24), the VPN host retains the same IP Address through the changes of network, the port forward rule is added,  I see no reason why your VPN has stopped.
As stated previously, a retail router in this case a Hub two does not block any out bound ports, the need for a port forward rule is to ensure the inbound wireguard connection has a destination IP Address.
So turning Hubs firewall OFF will not help, you would still need a port forward rule.
This message
In this case for a inbound wireguard server connection the hidden IP Address would be the remote device from where the connection is coming from.
So was the home server IP address manually setup through the devices network propertied or DHCP ?
For static (manual set) Is 192.168.1.101, default gateway and DNS IP address are they correct?
Hub default IP is 192.168.1.254.
I would always test a VPN server OFF network not locally on the LAN.
Fixes: 1,495
Moderators Note
This topic has been moved from Broadband to My Router
johnmcdtf
[solved] Re: VPN port forwarding outgoing blocked
SOLVED quick note that it appears resolved now.
As a further test I installed wireguard on a raspberry pi and this worked from LAN and WAN sides.  So that indicated that it is NOT a router issue.  i.e. the port forward worked as expected to the pi.
So, going back to my server and thinking hard about the setup.  I discover it is not accessing external domains reliably.  i.e. not even deb.debian.org can be pinged.
I disabled IPv6 on the server and router in case this was relevant.  But does not fix issue.
I then consider the addressing.  The server is assigned a static address at both router and locally on the server.  I change the server back to DHCP request.  It is assigned the same IP address Now is can ping domains and the VPN is working!
reenable IPv6 and VPN continues to work ok.
Fixes: 585
Re: [solved] Re: VPN port forwarding outgoing blocked
@johnmcdtf thanks for letting us know its fixed.
The locally applied static settings will override anything. It sounds like the default gateway wasn't correct and so it had no route to the outside world. Changing to DHCP will have corrected the gateway address since the DHCP server will have supplied it.
@MisterW
I did consider there was something adrift with the network setting on the home server, that was my thinking behind.
Simple fix in the end..
Fixes: 585
I guessed that @Dan_the_Van . However, one would have expected that the BT router and the PN one would have the same default IP and so any static settings on the server would be the same ?
johnmcdtf
I can't really explain the cause.
The server was static IP set but router apparently lost the correct route. Even when connected directly to a Lan port on the router it was not working. I suspect the MAC /IP was incorrect, but by not using DHCP this could not self correct. Changing the server to DHCP allowed the router to fix this error.
