My hub2 shows IPv6 status enabled but network status disabled
do2023
My hub2 shows IPv6 status enabled but network status disabled.
What are the advantages/disadvantages for enabling  the network status.
Is IPv6 better than IPv4?
The DNS option is set to IPv4 only.
not sure about ip protocols and the wider network environment
Best Regards
5 REPLIES 5
Fixes: 1,495
Re: My hub2 shows IPv6 status enabled but network status disabled
PN doesn't have IPv6 as of yet, so although the hub2 supports it you can't use it.
Fixes: 388
@do2023 Can you post a screenshot showing this?
IPV6 is currently not available on Plusnet.
@dvorak beat me to it.
Fixes: 1,495
@jab1  - this is what the OP was referring to. It'll be the same on all hub2's.
Fixes: 388
Ah - OK, @dvorak . I've never had a Hub2, so not had chance to investigate one fully.
do2023
Many thanks for the info. great quick response.
