MelCloud and Weatherlink Devices
SimonR1066
Hi I have just signed up to PlusNet. Before I had full fibre my heating system using MelCloud and my weather station using Weatherlink both worked fine. But now the apps won't connect to the wifi. I have googled the issue and they will only connect to a 2.4Ghz connection. So I have disabled the 5Ghz connection but still can not connect. Other options include using extenders and connecting to a guest network or using a different router.
I am not very tech savvy and PlusNet weren't able to resolve the issues so I wonder if anyone here has come across this issue and found a solution.
Many thanks, Simon
6 REPLIES 6
Fixes: 388
Re: MelCloud and Weatherlink Devices
@SimonR1066 Welcome to the forums.I don't know either of those applications, but I  wonder if they are still trying to connect to your previous ISPs router? Do they have a factory reset option?
SimonR1066
Hi John, thanks for the welcome. No neither have reset options. Both devices just have a pairing button that works with the WPS button but they don't want to connect to the wifi.
Fixes: 388
@SimonR1066 In that case, I'm stumped. Sorry I can't help any more - maybe someone else can?
Fixes: 480
@SimonR1066
See following to reset both devices. Once reset, reconnect as before.
Weatherlink
https://support.davisinstruments.com/article/a5r5mbkrr2-how-do-i-reboot-my-weather-link-console
MelCloud
https://www.youtube.com/watch?v=wsQhin8Zg7g
Once reconnected you should be able to switch the 5 GHz band back on.
SimonR1066
Hi Baldrick1, thanks for your reply.
The weatherlink console I have is a standalone console 6100UK that has no way of accessing a screen. In the past I have just used my weatherlink app on my phone that finds the console through bluetooth. From what I have been told by others it is the security of the router that is preventing the console from pairing.
And I think the same issue applies to the MelCloud. I did go through the Youtube video and tried that but they still are not pairing.
I am going to buy a wifi extender to see if that resolves the issue and hopefully I will be able to set it up easily.
Thanks again for your help though , I do appreciate it.
mystreet1
Seasoned Pro
Fixes: 7
@SimonR1066, before doing anything else. Change the WiFi SSID and password on the router to your old working one and see if they connect.
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
