BT smarthub2 query
arbeeuk
BT smarthub2 query
Just switched to Plusnet from BT. today, Everything working perfectly  with my BTsmarthub2 router.
My query is - does BTsmarthub 2 still get updates etc automatically?.
2 REPLIES 2
Re: BT smarthub2 query
@arbeeuk
I believe it will still receive updates, but I doubt they would be relevant for a plusnet connection.
If you take a look at the event.log on the hub, likely location >Advanced settings >Technical log >Event log
If there is a category "TR069 or CWMP" look there is see if there are any successful connection message to the CWMP server.
For a Hub two they read, start from the bottom line.
22:42:02, 29 Oct. CWMP: HDM socket closed successfully.
22:42:02, 29 Oct. CWMP: HTTP authentication success from pbthdm.x.x.x
22:42:02, 29 Oct. CWMP: HDM socket opened successfully.
22:42:02, 29 Oct. CWMP: session completed successfully
22:42:01, 29 Oct. CWMP: HDM socket opened successfully.
22:42:01, 29 Oct. CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
22:42:01, 29 Oct. CWMP: Session start now, server: https://pbthdm.x.x.x, Event code: 2 PERIODIC
22:42:01, 29 Oct. CWMP: Initializing transaction for event code 2 PERIODIC
The above message code 2 PERIODIC are for an active connection CWMP/TR069 "I am here messages" they should repeat every 24 hours but not necessarily at the same time of my example
If you're not sure copy/paste a log entry example from your hub.
arbeeuk
Thanks for the quick response.
The hub has the latest firmware (april 2025) so I will see how things go for a while.
