Link cctv dvr to internet hub 2
Jboyle57
My cctv error message gateway unreachable … cannot view cameras on phone app as iCloud offline
15 REPLIES 15
Fixes: 382
Re: Link cctv dvr to internet hub 2
@Jboyle57 Is this a new phone, or a new problem ?- the 'iCloud offline' message sounds like you haven't activated it.
Fixes: 147
Are you seeing this message on your DVR device?
If yes, the Hub Two IP Address is 192.168.1.254 so the default gateway address needs to be this.
HTH
Jboyle57
I have tried changing gateway to that but still not working . It is on the dvr monitor . But still saying offline
Jboyle57
New problem … I just changed over on monday from Bt to plusnet which is when problem started
Fixes: 476
Moderators Note
This topic has been moved from Broadband to My Router
Jboyle57
How do I activate?
Fixes: 147
@Jboyle57
It would be helpful if you let the community know which DVR you are using and how it is currently configured, someone here might have the same product and therefore help you or check the manufacture's site for support pages.
Dan
Jboyle57
Hi it’s zosi H264 … sorry but don’t know anything about configuration 🥴
Fixes: 147
Thanks for the model.
I'm out all day, hopefully someone will come along who can help.
Fixes: 579
@Jboyle57 there's a guide here https://learncctv.com/zosi-dvr-internet-connection/ about connecting the VDr to the internet.
Maybe you could progress through that and post a screen dump of the Network status screen. That may help to determine what the problem is
Jboyle57
Thanks MisterW… I will show this to my son who’s better at technology than me. I do know that I don’t get the same menu when I go into settings. Maybe mine is an older model… think it’s been installed for 3 yrs .
Jboyle57
We’ve managed now to get the dvr online. I uninstalled them reinstalled the zosi cloud app on my iPhone to see if that was problem a few days ago( which wasn’t) but cannot remember the password I used and now cannot open camera view on mobile. I have tried to reset password but ofcourse can’t without original password. Does anyone know how I can sort this?
Tags (1)
Fixes: 147
Good news about it now working.
Does the app not have a 'Forgot Password' on the login screen? This should all be documented somewhere
Try  https://supports.zositech.com/hc/en-us
I see there is also Zosi cloud for windows app, which might be easier to use.
Jboyle57
Unfortunately there is no forgot password selection. It has reset… u get a code emailed but when u try to reset it asks for original password which ofcourse I’ve forgotten!😱
