One Hub Watchdog Resets (Cause 0x3)
williamjt97
After my last post (11/09/21) I didn't have any disconnects for a shortwhile but they did come back after a bit. But recently they have ramped back up again in how many are happening per week.
When looking in the Event log for the router every time it's disconnecting the message that appears says
"Boot reason: watchdog reset (cause: 0x3)"
I have tried all the different fixes I could find from various online posts (turning firewall off, having the router be the only thing plugged into a dual wall socket, turn 5ghz wifi off, turn 2.4ghz wifi off, reset it, leave it turn off for an hour but sadly none of these have resolved the issue.
According to this post here the issue was with the router itself as a replacement one fixed their issue.
Event log:
21:29:34, 03 Aug.	( 109.980000) Admin login successful by 192.168.1.67 on HTTP
21:29:34, 03 Aug.	IN: BLOCK [15] Default policy (TCP [20.54.37.64]:443-​>[146.90.122.88]:56644 on ppp3)
21:29:30, 03 Aug.	BLOCKED 1 more packets (because of Default policy)
21:29:30, 03 Aug.	IN: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [104.98.228.241]:443-​>[146.90.122.88]:60722 on ppp3)
21:29:29, 03 Aug.	IN: BLOCK [15] Default policy (TCP [20.54.37.64]:443-​>[146.90.122.88]:56644 on ppp3)
21:29:26, 03 Aug.	( 102.080000) New GUI session from IP 192.168.1.67
21:29:26, 03 Aug.	BLOCKED 1 more packets (because of Default policy)
21:29:25, 03 Aug.	IN: BLOCK [15] Default policy (TCP [20.54.37.64]:443-​>[146.90.122.88]:56644 on ppp3)
21:29:25, 03 Aug.	BLOCKED 2 more packets (because of Default policy)
21:29:24, 03 Aug.	IN: BLOCK [15] Default policy (TCP [20.54.37.64]:443-​>[146.90.122.88]:56644 on ppp3)
21:29:23, 03 Aug.	IN: BLOCK [15] Default policy (TCP [31.192.111.224]:57812-​>[146.90.122.88]:5986 on ppp3)
21:29:23, 03 Aug.	BLOCKED 1 more packets (because of Default policy)
21:29:22, 03 Aug.	( 97.790000) CWMP: session closed due to error: WGET TLS error
21:29:22, 03 Aug.	IN: BLOCK [15] Default policy (TCP [135.92.6.73]:443-​>[146.90.122.88]:50772 on ppp3)
21:29:21, 03 Aug.	( 96.480000) NTP synchronization success!
21:29:19, 03 Aug.	( 94.420000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
21:29:19, 03 Aug.	( 94.410000) CWMP: Session start now. Event code(s): '1 BOOT'
21:29:19, 03 Aug.	IN: BLOCK [15] Default policy (TCP [54.236.161.4]:443-​>[146.90.122.88]:56854 on ppp3)
21:29:19, 03 Aug.	OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.67]:60722-​>[104.98.228.241]:443 on ppp3)
21:29:18, 03 Aug.	( 93.600000) NTP synchronization start
21:29:17, 03 Aug.	( 92.630000) WAN operating mode is VDSL
21:29:17, 03 Aug.	( 92.630000) Last WAN operating mode was VDSL
21:29:16, 03 Aug.	( 91.500000) PPP IPCP Receive Configuration ACK
21:29:16, 03 Aug.	( 91.500000) PPP IPCP Send Configuration Request
21:29:16, 03 Aug.	( 91.490000) PPP IPCP Receive Configuration NAK
21:29:16, 03 Aug.	( 91.490000) PPP IPCP Send Configuration ACK
21:29:16, 03 Aug.	( 91.480000) PPP IPCP Receive Configuration Request
21:29:16, 03 Aug.	( 91.480000) PPP IPCP Send Configuration Request
21:29:15, 03 Aug.	( 90.530000) PPPoE is up -​ Down Rate=79995Kbps, Up Rate=20000Kbps; SNR Margin Down=12.8dB, Up=12.7dB
21:29:15, 03 Aug.	( 90.520000) CHAP authentication successful
21:29:15, 03 Aug.	( 90.480000) CHAP Receive Challenge
21:29:15, 03 Aug.	( 90.480000) Starting CHAP authentication with peer
21:29:15, 03 Aug.	( 90.480000) PPP LCP Receive Configuration ACK
21:29:15, 03 Aug.	( 90.480000) PPP LCP Send Configuration Request
21:29:15, 03 Aug.	( 90.470000) PPP LCP Receive Configuration Reject
21:29:15, 03 Aug.	( 90.470000) PPP LCP Send Configuration ACK
21:29:15, 03 Aug.	( 90.470000) PPP LCP Receive Configuration Request
21:29:15, 03 Aug.	( 90.470000) PPP LCP Send Configuration Request
21:29:11, 03 Aug.	( 86.240000) PTM over DSL is up
21:28:55, 03 Aug.	( 70.970000) CWMP: session closed due to error: Could not resolve host
21:28:55, 03 Aug.	( 70.960000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
21:28:55, 03 Aug.	( 70.960000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
21:28:25, 03 Aug.	( 40.690000) CWMP: session closed due to error: Could not resolve host
21:28:22, 03 Aug.	( 37.230000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
21:28:22, 03 Aug.	( 37.220000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
21:28:21, 03 Aug.	( 36.950000) CWMP: Initializing transaction for event code 1 BOOT
21:28:20, 03 Aug.	( 35.780000) WiFi auto selected channel 48
21:28:20, 03 Aug.	( 35.780000) 36-​95::40-​95::44-​95::48-​93::52-​93::56-​94::60-​93::64-​93::100-​94::104-​94::108-​96::112-​96::116-​96::120-​97::124-​97::128-​98
21:28:20, 03 Aug.	( 35.780000) 5 GHz Wireless: Rescan, Reason: 'Power-​up'
21:28:20, 03 Aug.	( 35.780000) WiFi auto selected channel 6
21:28:20, 03 Aug.	( 35.780000) 1-​97::2-​96::3-​97::4-​96::5-​97::6-​96::7-​97::8-​97::9-​98::10-​98::11-​99::12-​98::13-​98
21:28:20, 03 Aug.	( 35.770000) 2.4 GHz Wireless: Rescan, Reason: 'Power-​up'
21:28:20, 03 Aug.	( 35.770000) Wire Lan Port 4 up
21:28:20, 03 Aug.	( 35.070000) WAN Auto-​sensing running.
21:28:16, 03 Aug.	( 31.350000) System up, firmware version: 4.7.5.1.83.8.289.1.3
21:28:14, 03 Aug.	( 29.030000) WPA2 mode selected
21:28:14, 03 Aug.	( 29.030000) WPS enabled
21:28:11, 03 Aug.	( 26.850000) WPA2 mode selected
21:28:11, 03 Aug.	( 26.850000) WPS enabled
21:28:02, 03 Aug.	( 17.800000) System start
21:28:02, 03 Aug.	( 17.800000) Boot reason: watchdog reset (cause: 0x3)
 Before this section of the event log the last message was
19:30:28, 03 Aug.	(451878.000000) NTP synchronization success!
2 hours before the disconnect.
The router will reboot itself, flash green then solid blue then flash orange then flask green to solid blue again, at this point the internet is working again.
While it's rebooting there is no noise or static on the landline just the normal dial tone.
Could this be looked into?
Thank-you.
7 REPLIES 7
williamjt97
Re: One Hub Watchdog Resets (Cause 0x3)
After posting this it happened again, except this time the event log jumped to the future!
01:01:06, 30 Aug. ( 67.470000) Admin login successful by 192.168.1.67 on HTTP
01:00:40, 30 Aug. ( 40.860000) CWMP: session closed due to error: Could not resolve host
01:00:38, 30 Aug. ( 39.610000) New GUI session from IP 192.168.1.67
01:00:36, 30 Aug. ( 37.170000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
01:00:36, 30 Aug. ( 37.170000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
01:00:36, 30 Aug. ( 36.890000) CWMP: Initializing transaction for event code 1 BOOT
01:00:34, 30 Aug. ( 35.660000) WiFi auto selected channel 48
01:00:34, 30 Aug. ( 35.660000) 36-​95::40-​95::44-​94::48-​94::52-​93::56-​93::60-​93::64-​93::100-​95::104-​96::108-​96::112-​96::116-​96::120-​97::124-​96::128-​98
01:00:34, 30 Aug. ( 35.650000) 5 GHz Wireless: Rescan, Reason: 'Power-​up'
01:00:34, 30 Aug. ( 35.650000) WiFi auto selected channel 11
01:00:34, 30 Aug. ( 35.650000) 1-​95::2-​97::3-​96::4-​95::5-​96::6-​96::7-​97::8-​98::9-​98::10-​99::11-​103::12-​97::13-​99
01:00:34, 30 Aug. ( 35.640000) 2.4 GHz Wireless: Rescan, Reason: 'Power-​up'
01:00:34, 30 Aug. ( 35.640000) Wire Lan Port 4 up
01:00:33, 30 Aug. ( 34.660000) WAN Auto-​sensing running.
01:00:30, 30 Aug. ( 31.160000) System up, firmware version: 4.7.5.1.83.8.289.1.3
01:00:28, 30 Aug. ( 28.900000) WPA2 mode selected
01:00:28, 30 Aug. ( 28.900000) WPS enabled
01:00:25, 30 Aug. ( 26.620000) WPA2 mode selected
01:00:25, 30 Aug. ( 26.620000) WPS enabled
01:00:16, 30 Aug. ( 17.600000) System start
01:00:16, 30 Aug. ( 17.600000) Boot reason: watchdog reset (cause: 0x3)
After refreshing the page log is now back at 3rd Aug and correct time.
Fixes: 388
@williamjt97 Sounds like a failing Hub - how long have you had it?
williamjt97
I've had it since July last year.
Fixes: 388
@williamjt97 OK, not that long, but from memory, there seemed to be a dodgy batch of Hubs at one point (can't remember when), this may be one.
A member of the Help Team will pick this up at some point, hopefully read the whole topic, and agree with me that it needs replacing.
bobpullen
Fixes: 331
@williamjt97 - showing signs of a physical fault. I've arranged for a replacement hub to be shipped to you. Should turn up on Saturday all being well.
williamjt97
Thank-you very much, will let you know how it gets on.
williamjt97
I've had the router for a week now and has been working great. 0 crashes so far. Thank-you
