Plusnet FTTP and Eero
brightleap
I used to have Plusnet FTTC and was using an HG612 modem in bridge mode connected to my Eeros.  All worked perfectly.
I've just upgraded to FTTP via Plusnet and they've sent a Hub Two.  I know I could now use the Hub Two in bridge mode (Hub One didn't support this).
However the Eeros have now also been updated to allow you to enter PPPOE settings for your ISP.  Does this mean I can just connect the Eero directly to the ONT and do away with the separate modem / Hub Two?  It feels like I should be able to, but I can't get it working for some reason.  Maybe I'm mistaken in thinking that the ONT acts as the modem?
6 REPLIES 6
Fixes: 585
Re: Plusnet FTTP and Eero
@brightleap  as long as the Eero can do PPPoE it should work fine. Double check the username/password , it should be <accountname>@plusdsl.net and the password that you use for the member centre.
The ONT does act as a modem
brightleap
Thanks, good to know it should work at least.  Pretty sure I was using the right details but I didn't have long to test, so will give it another go.
ksaro1
Have you set the VLAN (or frame) ID on the eero to be untagged? I think most routers default to setting a VLAN ID, which I believe will stop your connection from working. PN uses VLAN tagging on FTTC but not on Full Fibre.
RealAleMadrid
Fixes: 68
@brightleap  I agree with the comment from @ksaro1 There is no VLAN ID required on the router, the ONT deals with it just as the old Openreach modems did on FTTC.
brightleap
Thanks to everyone who replied...
I made a second attempt today and got it working fine.
As you may know, you have to configure the Eero devices on their mobile app.  What was happening was that there is a special character (a punctuation one) in my PPPOE password and when I entered it, my phone was automatically adding a space after the character, thus inserting a space in the entered password!
At least it was something simple!
Fixes: 585
@brightleap thanks for letting us know. That may be useful for others in the future.
