Line noise caused by router
- My Router
- Line noise caused by router
21-06-2020 11:09 AM
For the past few days I've noticed a fairly loud hissing sound on the line when making phone calls. If I switch the router off the noise stops immediately, and returns when I power the router back on. I've tried a new ADSL filter but this makes no difference, so I think the router itself is faulty.
Can you arrange a replacement router for me.
Thanks.
Re: Line noise caused by router
20-06-2020 6:45 PM - edited 20-06-2020 6:49 PM
Plus they could run some diagnostics to see if there is a problem on your line which is causing the interference.
Is your router plugged into an extension socket or the master socket?
21-06-2020 11:08 AM
Thanks, it's an extension socket, but I've tried the master as well and get the same effect, so I'm pretty sure it's the router.
I see that there is a My Router board which is maybe where this query should be, so I'll repost there.
Thanks for the help.
21-06-2020 11:29 AM
Is phone base too close to router and generating noise on phone line?
21-06-2020 12:16 PM
Obviously the router is generating interference - so it must be faulty.
21-06-2020 12:39 PM
Not necessarily.
This symptom is often caused by a high resistance (HR) joint somewhere on the line twixt house and exchange.
ADSL2+ Billion 8800NL
21-06-2020 3:50 PM
Try dialling 17070 (Quiet line test) on your phone - ideally using a wired phone [not the type that uses a base unit].
If you hear anything more than absolute silence, report a voice fault.
22-06-2020 10:37 AM
The router is nowhere near the phone base station.
I've done the 17070 quiet line test - the line is silent with the router powered off, hissing noise present with the router powered on.
Seems unlikely it's a line fault given the noise is only there with the router powered on?
23-06-2020 11:11 AM
Hi @leswzz99,
I'm sorry to hear that you're experiencing issues with the services. I've tested your line today and we've not been able to detect any underlying faults. As this is the case I would recommend running through this troubleshooting guide if you're still hearing noise on the line.
If you still hear noise on the line following this then please let us know and report the fault online here.
23-06-2020 11:13 AM
Hi @leswzz99,
I can see that you've opened another thread on this topic and I've responded there. In the future I would ask that you please keep all posts about an issue/query contained to one thread as it helps us respond more quickly and efficiently.
23-06-2020 12:01 PM - edited 23-06-2020 12:08 PM
This topic has been moved from ADSL Broadband to My Router and topics merged.
Customer and Forum Moderator. Windows 10 Firefox 86.0 (64-bit)
