Hub2 not showing some device names
cdr8
My new Hub2 is showing some connected devices as unknown even though they have names. e.g. my iPhone and iPad have names but hub manager has no icon or name showing. My old iPad is shown with name. Any idea how to fix this?
13 REPLIES 13
Fixes: 1,495
Re: Hub2 not showing some device names
Moderators Note
This topic has been moved from Broadband to My Router
Fixes: 1,495
I suspect it's because you have 'Private Wi-Fi Address' switched on in the settings.
This rotates the mac address each time and will not reflect the device properly.
Switch it off and they should appear.
cdr8
You are correct. The phone says it reduces tracking so I thought it best to leave it on. At least I know why now thank you.
Fixes: 1,495
Probably won't matter if you just switch it off for your home Wi-Fi, I don't have it on for home but do for all public ones.
Fixes: 388
Sorry to hijack the topic, but where do you find this setting? I thought I knew most of Apples quirks.😉
Fixes: 1,495
iOS / iPad OS: Settings > Wi-Fi > <attached wifi network> middle of the settings.
Doesn't appear to have been implemented on macOS (yet).
Fixes: 388
Cheers @dvorak  - might sort a quirk on my Fritzbox.
cdr8
How do you do that? It seems to be on or off on my iPhone and iPad.
Fixes: 1,495
It's a per wi-fi setting, not a system wide setting.
cdr8
Ah I see thank you
cdr8
It seems to remember the name even when turned off again. I changed one name and it doesn't update on hub manager. I have refreshed hub manager and even exited it completely.
greygit
The 'paranoid' might like to consider that the logs of the Hub2 are uploaded to plusnet (or BT) for perfectly innocent reasons and adjust their personal 'paranoia' level accordingly.
N.B. Like your nym. Real bread and butter for tea. The theme tune to the Hovis ad. of old (directed by Ridley Scott) comes from Dvorak's "from the New World" symphony.
greygit
There's at least one RFC covering locally assigned/managed MAC addresses. What Apple do isn't outside the box. Doing the same on an Android is near impossible.
