Hub1 not for fit for purpose
- My Router
- Hub1 not for fit for purpose
06-03-2020 10:01 AM
Re: Hub1 not for fit for purpose
06-03-2020 10:02 AM
on 06-03-2020 10:21 AM - last edited on 06-03-2020 10:33 AM by dvorak
Telephone call, details given below.
[CSA Removed] - CSC Analyst
8:36pm, Thursday 5 Mar 2020
Moderators Note: CSA name removed as per Forum rules
06-03-2020 10:25 AM
TP-LINK TL-WR940N WiFi Cable & Fibre Router - N450, Single-band
Product code: 227992 from pc world. Advertised as
For standard internet connections
N450
Ideal for low internet use
Single-band (2.4 GHz)
And plusnet will refund the £24.99.
Well that will get rid of the 5GHz problem won't it.
06-03-2020 10:26 AM - edited 06-03-2020 10:32 AM
As far as I am aware the big problem with the Hub One concerns wireless performance. The official answer to your question What Now? Is that Plusnet is working on it.
Also if you read the Router board you will learn that BT Smarthub 6s are available for very little money, have better performance and work without major issues.
Edit.
Grab one, get the £24.99 and you will be in profit.
it sounds like the CSC Analyst has really dropped Plusnet, and himself, in it stating this!
06-03-2020 10:38 AM
@Baldrick1. You say the problem is with the wireless performance, that's a pretty fundamental part of the hub1. The other party of the hub1 is the modem section. Perhaps I should consider a mesh system if I was considering spending my own £ in solving my problem but can I be sure that even the modem section of the hub1 is ok. Seeing that a mesh would connect to the Gigabit Ethernet output of the hub1.
It also seems there is a problem that whilst the likes of Bob Bullen is working to try and find what the problem is, the people you talk to on the telephone are not aware of him or what is going on.
06-03-2020 10:41 AM
06-03-2020 11:03 AM
Didn't really need the name. Be interesting to see if this an official line - but I doubt that very much.
06-03-2020 11:26 AM
Whoever advised you to get that TP-link router hasn't got a clue. It doesn't have a built in modem so would need an external modem to connect to the phone line for ADSL or FTTC
Looks like usual poor info from customer support.☹️
06-03-2020 11:26 AM
06-03-2020 11:28 AM
06-03-2020 12:09 PM - edited 06-03-2020 12:11 PM
It sounds like a panic reaction from a supervisor after his agent had dropped Plusnet in the deep and smelly stuff. In doing so another can of worms has been opened, that is, will Plusnet give all customers having problems with a Hub One £24.99 to buy their own router?
I have no doubt that a Plusnet staffer will be along soon to give an official ‘clarification’ of the situation.
06-03-2020 12:18 PM
But look at other threads. When plusnet provide their fibre extra, which is what I have, then supply a hub1, it looks as if, for some and maybe many, it does not work.
06-03-2020 12:43 PM
In the presence of both 2.4GHz and 5GHz bands having the same SSID name the cause of the operational issue could well be the connecting device not the router. IDevices are known to be prone to flip-flop between the two bands, something which can be mitigated by giving the two SSIDs distinctive names.
I have experienced such issues and I do not use Plusnet Hubs.
06-03-2020 12:58 PM
My 2.4MHz stream now sometimes slows to kbs, and subjectively seems to be getting worse, that is the frequency that this happens. It was last night when the final straw happened. A PS4 could not stream bt sport and that's when I looked at speeds and strength again.
So getting back to does not work.
I would say if a device I have is described as not for for purpose I say it does not work.
- My Router
