Hub One file sharing
Neil17
I've attached a usb stick to my Hub1 router in order to share data between my laptop and desktop (both running windows 10) but to get it to work I had to enable SMB1 protocol on both devices. Is the Hub1 enabled for SMB2?
5 REPLIES 5
Mav
Fixes: 515
Re: Hub One file sharing
Moderator's Note(s)
Thread moved from Fibre Broadband to My Router.
Forum Moderator and Customer
Fixes: 1,484
No, hub one is only SMB1
Neil17
Can it be updated to SMB2 as apparently there is a security issue with SMB1?
The simple answer to that @Neil17 is no.
markhawkin
Seasoned Pro
Fixes: 12
@Neil17
Depending on budget and how much you want the sharing I would recommend going down the Network Attached Storage (NAS) route.
I've tried a few different makes but now I would recommend a Synology over the cheaper options.
What I particularly like about it (as well as the obvious shared file storage) is that it will make any printer with a USB connection shared (and able to be printed to by Apple devices).
The Synology is also capable of lots of other clever stuff which may or may not be of use.
