Hub One Firmware Updates
FIXED- Subscribe to RSS Feed
- My Router
- Hub One Firmware Updates
Re: Hub One Firmware Updates
29-01-2018 3:14 PM
Ok that makes sense @bobpullen - once I have reset using the pin hole, do you need any information from me (i.e. my Routers MAC address etc - or have you already added my Hub One to the 'activated' list - haha can you see who I am etc without any details?!)
Thanks again for the continued help.
29-01-2018 3:24 PM
Thanks @bobpullen, will try another reset.
29-01-2018 5:48 PM
@ChrisaLyd12, no, I don't need any further info from you.
29-01-2018 6:39 PM - edited 29-01-2018 6:46 PM
Hi again @bobpullen,
I have performed a factory reset on our Hub One as requested and am now seeing this in the event log:
18:14:26, 29 Jan. | ( 1030.670000) CWMP: session closed due to error: Could not resolve host |
18:14:26, 29 Jan. | ( 1030.630000) CWMP: Server URL: https://ceased.tr69.p; Connecting as user: ACS username |
18:14:26, 29 Jan. |
( 1030.620000) CWMP: Session start now. Event code(s): '7 TRANSFER COMPLETE,M Download,0 BOOTSTRAP,4 VALUE CHANGE' |
Is this normal and should the router update soon?
The last 3 digits of our routers serial are: 776
Software version 4.7.5.1.83.8.226 Last updated Unknown
Thanks again for the continued support.
29-01-2018 6:59 PM
Hi @bobpullen,
Just checked log and noticed these entries, which seem to be consistent over time.
Cheers.
Time and date | Message |
15:53:12, 29 Jan. | ( 189.470000) CWMP: session completed successfully |
15:53:10, 29 Jan. | ( 188.090000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo |
15:53:04, 29 Jan. | ( 182.180000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
15:53:04, 29 Jan. | ( 182.170000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,7 TRANSFER COMPLETE,M Download,4 VALUE CHANGE' |
15:52:59, 29 Jan. | ( 176.980000) CWMP: Initializing transaction for event code M Download |
15:52:59, 29 Jan. | ( 176.980000) transfer complete: transfer error 9010: No response received from the upgrade server. |
15:52:59, 29 Jan. | ( 176.970000) CWMP: Download status=No response received from the upgrade server |
30-01-2018 6:10 PM
Plusnet Hub One | Software version 4.7.5.1.83.8.237.2.2 | Last updated 30/01/18
Excellent, thanks Bob.
30-01-2018 7:19 PM
Hey @Boshay and @bobpullen - NO FAIR!
Haha. 🙂
@Boshay did you reset using the pin hole on the back of the router and then restore your config file or did you leave the router at factory defaults?
Thanks - mine is still no updated 😞
30-01-2018 7:23 PM - edited 30-01-2018 7:26 PM
I tried the physical reset button but it didn't seem to respond, so went in to the Hub Manager and kicked off the factory default reset from there.
It appeared to update in the early hours.
Best of luck.
30-01-2018 7:25 PM - edited 30-01-2018 7:25 PM
Oh, didn't bother to restore config , thought a clean slate would be a good idea but hadn't changed much apart from device names.
30-01-2018 7:59 PM - edited 30-01-2018 8:00 PM
Hi @Boshay thanks for the replies, I reset our Hub One using the pin hole on the back and the LED's went green then reset, left it for a few hours and noticed that the tr069 logs looked different - NOTE the server URL changes and how once the config file was restored at 19:30 (ish) it reverted back to the 'ceased' address??:
What does your tr069 event log look like now it has been updated?
@bobpullen what do you think?
19:48:06, 30 Jan. | ( 1066.120000) CWMP: session closed due to error: Could not resolve host |
19:48:06, 30 Jan. | ( 1066.050000) CWMP: Server URL: https://ceased.tr69.p; Connecting as user: ACS username |
19:48:06, 30 Jan. | ( 1066.050000) CWMP: Session start now. Event code(s): '7 TRANSFER COMPLETE,M Download,0 BOOTSTRAP,4 VALUE CHANGE' |
19:33:05, 30 Jan. | ( 165.770000) CWMP: session closed due to error: Could not resolve host |
19:33:05, 30 Jan. | ( 165.730000) CWMP: Server URL: https://ceased.tr69.p; Connecting as user: ACS username |
19:33:05, 30 Jan. | ( 165.730000) CWMP: Session start now. Event code(s): '7 TRANSFER COMPLETE,M Download,0 BOOTSTRAP,4 VALUE CHANGE' |
19:32:35, 30 Jan. | ( 135.460000) CWMP: session closed due to error: Could not resolve host |
19:32:20, 30 Jan. | ( 131.540000) CWMP: Server URL: https://ceased.tr69.p; Connecting as user: ACS username |
19:32:20, 30 Jan. | ( 131.530000) CWMP: Session start now. Event code(s): '7 TRANSFER COMPLETE,M Download,0 BOOTSTRAP,4 VALUE CHANGE' |
19:31:13, 30 Jan. | ( 64.570000) CWMP: session closed due to error: Could not resolve host |
19:31:13, 30 Jan. | ( 64.550000) CWMP: Server URL: https://ceased.tr69.p; Connecting as user: ACS username |
19:31:13, 30 Jan. | ( 64.540000) CWMP: Session start now. Event code(s): '7 TRANSFER COMPLETE,M Download,0 BOOTSTRAP,4 VALUE CHANGE' |
19:30:43, 30 Jan. | ( 34.290000) CWMP: session closed due to error: Could not resolve host |
19:30:38, 30 Jan. | ( 29.680000) CWMP: Server URL: https://ceased.tr69.p; Connecting as user: ACS username |
19:30:38, 30 Jan. | ( 29.670000) CWMP: Session start now. Event code(s): '7 TRANSFER COMPLETE,M Download,0 BOOTSTRAP,4 VALUE CHANGE' |
19:30:38, 30 Jan. | ( 29.420000) CWMP: Initializing transaction for event code 0 BOOTSTRAP |
19:30:38, 30 Jan. | ( 29.420000) CWMP: Initializing transaction for event code M Download |
19:15:41, 30 Jan. | ( 184.470000) CWMP: session completed successfully |
19:15:40, 30 Jan. | ( 183.650000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo |
19:15:34, 30 Jan. | ( 178.060000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
19:15:34, 30 Jan. | ( 178.060000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,7 TRANSFER COMPLETE,M Download,4 VALUE CHANGE' |
19:15:30, 30 Jan. | ( 173.870000) CWMP: Initializing transaction for event code M Download |
19:15:30, 30 Jan. | ( 173.870000) transfer complete: transfer error 9010: Cannot resolve hostname. |
19:15:30, 30 Jan. | ( 173.870000) CWMP: Download status=Cannot resolve hostname. |
19:15:30, 30 Jan. | ( 173.870000) CWMP: session closed due to error: Could not resolve host |
19:15:27, 30 Jan. | ( 171.310000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
19:15:27, 30 Jan. | ( 171.300000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,4 VALUE CHANGE' |
19:15:25, 30 Jan. | ( 169.200000) CWMP: session completed successfully |
19:15:25, 30 Jan. | ( 169.050000) CWMP: Download file, FileType=1, FileName=bt_prod_secured.rms, Username=, CommandKey=10542818 |
19:15:23, 30 Jan. | ( 166.440000) CWMP: Set Parameter by TR069 Success |
19:15:21, 30 Jan. | ( 165.180000) CWMP: Set Parameter by TR069 Success |
19:15:21, 30 Jan. | ( 165.020000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo |
19:15:20, 30 Jan. | ( 163.470000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST |
19:15:20, 30 Jan. | ( 163.460000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST |
19:15:20, 30 Jan. | ( 163.430000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
19:15:20, 30 Jan. | ( 163.430000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST' |
19:15:19, 30 Jan. | ( 163.240000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST |
19:15:17, 30 Jan. | ( 160.980000) CWMP: session completed successfully |
19:15:17, 30 Jan. | ( 160.800000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo |
19:15:14, 30 Jan. | ( 158.190000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
19:15:14, 30 Jan. | ( 158.180000) CWMP: Session start now. Event code(s): '0 BOOTSTRAP' |
19:15:14, 30 Jan. | ( 157.990000) CWMP: session completed successfully |
19:15:13, 30 Jan. | ( 156.870000) CWMP: Initializing transaction for event code 0 BOOTSTRAP |
19:15:13, 30 Jan. | ( 156.720000) CWMP: Set Parameter by TR069 Success |
19:15:13, 30 Jan. | ( 156.550000) CWMP: HTTP authentication success from https://dbtpnhdmw.bt.mo |
19:15:10, 30 Jan. | ( 154.310000) CWMP: Server URL: https://dbtpnhdmw.bt.mo; Connecting as user: Default username |
19:15:10, 30 Jan. | ( 154.310000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST' |
19:15:10, 30 Jan. | ( 154.120000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST |
19:15:07, 30 Jan. | ( 150.630000) CWMP: session completed successfully |
19:15:06, 30 Jan. | ( 149.550000) CWMP: Set Parameter by TR069 Success |
19:15:06, 30 Jan. | ( 149.390000) CWMP: HTTP authentication success from https://dbtpnhdmw.bt.mo |
19:14:48, 30 Jan. | ( 142.810000) CWMP: Server URL: https://dbtpnhdmw.bt.mo; Connecting as user: Default username |
19:14:47, 30 Jan. | ( 142.800000) CWMP: Session start now. Event code(s): '0 BOOTSTRAP,4 VALUE CHANGE' |
19:13:41, 30 Jan. | ( 75.820000) CWMP: session closed due to error: Could not resolve host |
19:13:40, 30 Jan. | ( 75.800000) CWMP: Server URL: https://dbtpnhdmw.bt.mo; Connecting as user: Default username |
19:13:40, 30 Jan. | ( 75.800000) CWMP: Session start now. Event code(s): '0 BOOTSTRAP,4 VALUE CHANGE' |
19:13:10, 30 Jan. | ( 45.640000) CWMP: session closed due to error: Could not resolve host |
19:13:01, 30 Jan. | ( 36.660000) CWMP: Server URL: https://dbtpnhdmw.bt.mo; Connecting as user: Default username |
19:13:01, 30 Jan. | ( 36.650000) CWMP: Session start now. Event code(s): '0 BOOTSTRAP,4 VALUE CHANGE' |
19:13:01, 30 Jan. | ( 36.300000) CWMP: Initializing transaction for event code 0 BOOTSTRAP |
30-01-2018 8:11 PM
I wonder if restoring your config restored the invalid 'ceased' address.
I didn't restore my config.
I think I reset my hub at around 18:30 and the update occurred around 01:30 the following morning, so maybe try a reset and leave for a day at least, checking to see if the update has been applied?
Log below.
Cheers.
Boshay
30-01-2018 8:22 PM
@Boshay thanks for the log - makes sense that the restored config file put back the 'ceased' server details - annoying to say the least but i'll give the reset another go and leave it at defaults.
Appreciate all the help so far - hopefully our Hub One will get it's update in the morning like yours did 🙂
30-01-2018 8:37 PM
Surely that's wrong - restoring server config shouldn't put back that sort of data?
So I have to reset my router to factory settings and then manually re-create all the configuration if I want the update process to work?
@bobpullen - can you confirm that restoring user settings replaces the server details for the updates with the ceased server name?
30-01-2018 9:01 PM
Can't disagree it but does appear to be the only explanation so far. Interestingly when I tried my first reset a few days ago I restored my config almost immediately and updates continued to fail, only once I reset and didn't restore my config did the updates succeed and pretty quickly too.
I know it just one instance but empirically it appears to be the case.
Hopefully @ChrisaLyd12 can prove it one way or the other over the next couple of days.
Cheers.
Boshay.
30-01-2018 10:12 PM
@SteveA @Boshay I have since reset my Hub One (again, again!) and have not restored my config and have been monitoring the TR069 logs this evening - I can confirm that my logs are now pointing towards the correct server URL and not the ceased as seen when restoring my config: ! no updates yet but hopefully it will get pushed overnight - still on 4.7.5.1.83.8.226 (although says that it was updated today - silly thing!)
21:18:09, 30 Jan. | ( 1129.230000) CWMP: session completed successfully |
21:18:07, 30 Jan. | ( 1128.080000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo |
21:18:03, 30 Jan. | ( 1123.710000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
21:18:03, 30 Jan. | ( 1123.710000) CWMP: Session start now. Event code(s): '7 TRANSFER COMPLETE,M Download,4 VALUE CHANGE' |
21:18:03, 30 Jan. | ( 1123.460000) CWMP: Initializing transaction for event code M Download |
21:18:03, 30 Jan. | ( 1123.460000) transfer completed successfully |
21:18:02, 30 Jan. | ( 1122.950000) CWMP: Download status=OK |
21:17:42, 30 Jan. | ( 1102.420000) CWMP: session completed successfully |
21:17:42, 30 Jan. | ( 1102.240000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo |
21:17:39, 30 Jan. | ( 1099.310000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
21:17:39, 30 Jan. | ( 1099.310000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,4 VALUE CHANGE' |
21:17:38, 30 Jan. | ( 1099.060000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST |
21:17:38, 30 Jan. | ( 1098.980000) CWMP: session completed successfully |
21:17:38, 30 Jan. | ( 1098.830000) CWMP: Download file, FileType=1, FileName=bt_prod_secured.rms, Username=, CommandKey=10546013 |
21:17:38, 30 Jan. | ( 1098.660000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo |
21:17:33, 30 Jan. | ( 1094.100000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
21:17:33, 30 Jan. | ( 1094.090000) CWMP: Session start now. Event code(s): '2 PERIODIC,4 VALUE CHANGE' |
21:17:33, 30 Jan. | ( 1093.850000) CWMP: Initializing transaction for event code 2 PERIODIC |
21:02:35, 30 Jan. | ( 195.450000) CWMP: session completed successfully |
21:02:34, 30 Jan. | ( 194.590000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo |
21:02:32, 30 Jan. | ( 192.220000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
21:02:32, 30 Jan. | ( 192.220000) CWMP: Session start now. Event code(s): '7 TRANSFER COMPLETE,M Download,4 VALUE CHANGE' |
21:02:31, 30 Jan. | ( 191.970000) CWMP: Initializing transaction for event code M Download |
21:02:31, 30 Jan. | ( 191.970000) transfer completed successfully |
21:02:31, 30 Jan. | ( 191.690000) CWMP: Download status=OK |
21:02:11, 30 Jan. | ( 171.520000) CWMP: session completed successfully |
21:02:11, 30 Jan. | ( 171.340000) CWMP: Download file, FileType=1, FileName=bt_prod_secured.rms, Username=, CommandKey=10545646 |
21:02:11, 30 Jan. | ( 171.180000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo |
21:02:09, 30 Jan. | ( 169.380000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
21:02:09, 30 Jan. | ( 169.380000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,4 VALUE CHANGE' |
21:02:09, 30 Jan. | ( 169.130000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST |
21:02:08, 30 Jan. | ( 168.790000) CWMP: session completed successfully |
21:02:08, 30 Jan. | ( 168.620000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo |
21:02:05, 30 Jan. | ( 166.110000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
21:02:05, 30 Jan. | ( 166.100000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE' |
21:01:35, 30 Jan. | ( 135.850000) CWMP: session closed due to error: WGET TLS error |
21:01:19, 30 Jan. | ( 131.630000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
21:01:19, 30 Jan. | ( 131.620000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE' |
21:00:11, 30 Jan. | ( 63.730000) CWMP: session closed due to error: Could not resolve host |
21:00:11, 30 Jan. | ( 63.710000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
21:00:11, 30 Jan. | ( 63.690000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE' |
20:59:41, 30 Jan. | ( 33.460000) CWMP: session closed due to error: Could not resolve host |
20:59:37, 30 Jan. | ( 29.530000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
20:59:37, 30 Jan. | ( 29.520000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE' |
20:59:37, 30 Jan. | ( 29.280000) CWMP: Initializing transaction for event code 1 BOOT |
20:47:03, 30 Jan. | ( 208.760000) CWMP: session completed successfully |
20:47:03, 30 Jan. | ( 207.830000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo |
20:46:57, 30 Jan. | ( 202.210000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
20:46:57, 30 Jan. | ( 202.210000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,7 TRANSFER COMPLETE,M Download,4 VALUE CHANGE' |
20:46:51, 30 Jan. | ( 196.270000) CWMP: Initializing transaction for event code M Download |
20:46:51, 30 Jan. | ( 196.270000) transfer complete: transfer error 9010: Cannot resolve hostname. |
20:46:51, 30 Jan. | ( 196.270000) CWMP: Download status=Cannot resolve hostname. |
20:46:51, 30 Jan. | ( 196.270000) CWMP: session closed due to error: Could not resolve host |
20:46:48, 30 Jan. | ( 193.790000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
20:46:48, 30 Jan. | ( 193.790000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,4 VALUE CHANGE' |
20:46:46, 30 Jan. | ( 191.700000) CWMP: session completed successfully |
20:46:46, 30 Jan. | ( 191.390000) CWMP: Download file, FileType=1, FileName=bt_prod_secured.rms, Username=, CommandKey=10545305 |
20:46:43, 30 Jan. | ( 188.620000) CWMP: Set Parameter by TR069 Success |
20:46:42, 30 Jan. | ( 187.350000) CWMP: Set Parameter by TR069 Success |
20:46:42, 30 Jan. | ( 187.190000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo |
20:46:40, 30 Jan. | ( 185.590000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST |
20:46:40, 30 Jan. | ( 185.580000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST |
20:46:40, 30 Jan. | ( 185.550000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
20:46:40, 30 Jan. | ( 185.540000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST' |
20:46:40, 30 Jan. | ( 185.360000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST |
20:46:40, 30 Jan. | ( 185.010000) CWMP: session completed successfully |
20:46:40, 30 Jan. | ( 184.820000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo |
20:46:37, 30 Jan. | ( 182.610000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
20:46:37, 30 Jan. | ( 182.610000) CWMP: Session start now. Event code(s): '0 BOOTSTRAP' |
20:46:37, 30 Jan. | ( 182.420000) CWMP: session completed successfully |
20:46:36, 30 Jan. | ( 181.490000) CWMP: Initializing transaction for event code 0 BOOTSTRAP |
20:46:36, 30 Jan. | ( 181.340000) CWMP: Set Parameter by TR069 Success |
20:46:36, 30 Jan. | ( 181.170000) CWMP: HTTP authentication success from https://dbtpnhdmw.bt.mo |
20:46:35, 30 Jan. | ( 179.930000) CWMP: Server URL: https://dbtpnhdmw.bt.mo; Connecting as user: Default username |
20:46:35, 30 Jan. | ( 179.930000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST' |
20:46:34, 30 Jan. | ( 179.750000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST |
20:46:34, 30 Jan. | ( 178.960000) CWMP: session completed successfully |
20:46:33, 30 Jan. | ( 177.880000) CWMP: Set Parameter by TR069 Success |
20:46:32, 30 Jan. | ( 177.720000) CWMP: HTTP authentication success from https://dbtpnhdmw.bt.mo |
20:46:30, 30 Jan. | ( 175.610000) CWMP: Server URL: https://dbtpnhdmw.bt.mo; Connecting as user: Default username |
20:46:30, 30 Jan. | ( 175.600000) CWMP: Session start now. Event code(s): '0 BOOTSTRAP,4 VALUE CHANGE' |
20:46:00, 30 Jan. | ( 145.440000) CWMP: session closed due to error: WGET TLS error |
20:45:45, 30 Jan. | ( 141.560000) CWMP: Server URL: https://dbtpnhdmw.bt.mo; Connecting as user: Default username |
20:45:45, 30 Jan. | ( 141.550000) CWMP: Session start now. Event code(s): '0 BOOTSTRAP,4 VALUE CHANGE' |
20:44:39, 30 Jan. | ( 75.770000) CWMP: session closed due to error: Could not resolve host |
20:44:39, 30 Jan. | ( 75.760000) CWMP: Server URL: https://dbtpnhdmw.bt.mo; Connecting as user: Default username |
20:44:39, 30 Jan. | ( 75.760000) CWMP: Session start now. Event code(s): '0 BOOTSTRAP,4 VALUE CHANGE' |
20:44:09, 30 Jan. | ( 45.600000) CWMP: session closed due to error: Could not resolve host |
20:44:00, 30 Jan. | ( 36.770000) CWMP: Server URL: https://dbtpnhdmw.bt.mo; Connecting as user: Default username |
20:44:00, 30 Jan. | ( 36.760000) CWMP: Session start now. Event code(s): '0 BOOTSTRAP,4 VALUE CHANGE' |
20:44:00, 30 Jan. | ( 36.410000) CWMP: Initializing transaction for event code 0 BOOTSTRAP |
