Hub One Firmware Updates
FIXED- Subscribe to RSS Feed
- My Router
- Hub One Firmware Updates
Re: Hub One Firmware Updates
31-01-2018 7:19 AM
Would you believe it:
Plusnet Hub One | Software version 4.7.5.1.83.8.237.2.2 | Last updated 31/01/18
It updated early morning - just been checking logs again and I can confirm that since factory resetting and NOT restoring our config, the router is looking to retrieve it's update files from the correct sever URL.
Bit of a poor setup if you ask me, but at least all is working.
This is a fantastic community with genuinely helpful people - thanks @bobpullen @Boshay and @SteveA
Could someone confirm that now @bobpullen has worked his magic, when another update is available for our router it will update on it's own and we won have to go through this hassle again?
Any idea what the new firmware offers in terms of features, fixes or security patches?
Hope all this has been worth it! 🙂 thanks again.
31-01-2018 7:33 AM
Good news it worked and interesting that it seems to prove our observations.
I too would be keen to see the change log for the updates.
Have to echo your thanks to the community too, thanks all.
Cheers.
Boshay.
02-02-2018 3:16 PM
@bobpullen,I have reset my router again and this time not restored the config file backup.The bottom of the webpage now says last updated 01/02/18 where as before it said unknown but the software version is still 4.7.5.1.83.8.226 ? Shouldn't it be version 4.7.5.1.8.237.2.2
10-02-2018 1:40 PM - edited 10-02-2018 1:49 PM
Did a reset.....
13:14:06, 10 Feb. | ( 174.410000) CWMP: session completed successfully |
13:14:05, 10 Feb. | ( 173.440000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo |
13:13:58, 10 Feb. | ( 166.950000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
13:13:58, 10 Feb. | ( 166.950000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,7 TRANSFER COMPLETE,M Download,4 VALUE CHANGE' |
13:13:54, 10 Feb. | ( 162.370000) CWMP: Initializing transaction for event code M Download |
Did a reload of config :
13:36:09, 10 Feb. | ( 1064.550000) CWMP: session closed due to error: Could not resolve host |
13:36:09, 10 Feb. | ( 1064.510000) CWMP: Server URL: https://ceased.tr69.p; Connecting as user: ACS username |
13:36:09, 10 Feb. | ( 1064.500000) CWMP: Session start now. Event code(s): '0 BOOTSTRAP,4 VALUE CHANGE' |
So for me reloading the config restores the ceased TR069 config.
I'm running:
Software version 4.7.5.1.83.8.226 Last updated 11/02/17
11-02-2018 6:28 AM
How do i check if my router is on the ceased list, i have had no firmware update since last year.
11-02-2018 9:51 AM
If you logon to the router
Navigate to Troubleshooting
Click on Event Logs
Select TR069 from the drop down
If you see things like
(23963.410000) CWMP: Server URL: https://ceased.tr69.p; Connecting as user: ACS username
Then you're on the ceased list
11-02-2018 11:22 AM
Many thanks, im not seeing anything like that. looks like it is looking for updates.
13-02-2018 6:25 PM
So as far as we can see, and it would be great if @bobpullen could confirm this, to get your router off the ceased list and get updates the following needs to happen:
- PN put your router back on the active list
- You do a hard reset of the router
- Router then starts doing TR069 exchanges
- You DO NOT restore your config as this restores the ceased TR069 configuration. You have to manually rebuild your config from the ground up
- After some length of time your router gets a firmware update
13-02-2018 6:38 PM
+081441+NQ70322953
3. Firmware version: Software version 4.7.5.1.83.8.226 Last updated Unknown
Is it possible to push the firmware upgrade through.
Thanks in advance
Karen
18-02-2018 3:16 PM
I can't do anything about pushing updates - I don't work for Plusnet
26-02-2018 6:57 PM
28-04-2018 4:43 PM
Hi. My router is having the same issue and disconnecting due to failure to update firmware. How do I go about getting it updated ?
28-04-2018 4:44 PM
+081441+NQ74806905 here is my serial number . can you add me please?
08-05-2018 4:37 PM
08-05-2018 5:19 PM
Mine updated fine,thanks
