Hub One - 5GHz WiFi issue
bobpullen
Fixes: 330
Re: Hub One - 5GHz WiFi issue
@Battle1066 & @dayvie - update has been sent your way. You'll need to power your hubs off/back on again to apply it.
@carolineh1 - Your hub was updated mid-July to a version that should not be subject to the 5GHz issue. It that when you started experiencing problems? I have pushed the most recent build to your hub but I'm not 100% convinced it's going to help. Let me know either way.
Edit@carolineh1 - the attempt to upgrade your hub actually failed, so I have scheduled it to happen as part of the wider deployment instead. If it is currently in use, then I would suggest you restart it anyway. Hopefully that will clear whatever issue is stopping the update from being pushed to you. You can then expect your router to reboot early in the morning one day next week after which it should be on version ending 1.3
MaiB
Bob, you very kindly pushed me the interim update before so I am now on
bobpullen
Fixes: 330
@MaiB - Done. You'll need to reboot to apply the update. Let me know how it goes.
MaiB
Thank you Bob.  I have done this and will let you know in due course.
Many thanks for all you are doing for us.
enrico94
Thanks @bobpullen - I've restarted the router and will monitor the stability of the 5 GHz network over the next few weeks.
NicDB
Hi @bobpullen
Could you push me the firmware update please? My S/N is +081441+NQ12583545
Kind regards
Nic
srgrice
Hi Bob,
Thanks for the post and info. I have joined PlusNet only recently and after constant connectively cuts outs, appear to have this issue. Could I be pushed the latest firmware in an attempt to resolve please?
1. Product name:Plusnet Hub
2. Serial number:+081441+NQ12505315
3. Firmware version:Software version 4.7.5.1.83.8.263 Last updated Unknown
4. Board version:Plusnet Hub One
Thanks for your assistance.
On a side note as a new customer I am pretty flabbergasted to find that there is such a widespread issue that is being left purely on customer to sort out. Pretty odd from BT really especially as my old BT router (which I have annoyingly only just recycled) was very similar, flawless and guess could have been reused in someway
keithscarfe
Hi.
Could I also get this firmware. Might help with my wi-fi issues also. Thanks. Keith
1. Product name: Plusnet Hub
2. Serial number: +081441+NQ90273449
3. Firmware version: Software version 4.7.5.1.83.8.263 Last updated 26/06/19
4. Board version:
Plusnet Hub One
Longliner
All Star
Fixes: 8
@srgrice
If your old router was a BT HH6, that's too bad! Many of us find the HH6 is far better  than the Hub One although Bob does his very best to meet the many requests for help. HH6 readily available on auction sites at £5 to £20 last time I looked, and there's an excellent guide to setup on this forum.
keithscarfe
Yes thanks, I do wanted to get a better router. I was thinking of something like a TPlink, Netgear or Dlink that sort of thing but I dont realy know which/what model. Since looking however, I have read on here how the BT HH6 is a good option. I will look out for one and follow the procedures on here. I was just after trying to improve what I currently have if it can be done quickly/easily. Cheers.
Mark60
Plusnet Hub One | Software version 4.7.5.1.83.8.289.1.3 | Last updated 15/10/21
Many thanks @bobpullen Since deployment connection on 5GHz has been rock solid
Mark
DaveH76
Another new PlusNet customer with firmware problems causing 5GHz connection issues...cannot connect anything to the 5GHZ...
Can I get on this list for a pushed firmware upgrade please @bobpullen ?
I have:
Hub One (serial number +081441+NQ41946761)
Firmware version 4.7.5.1.83.8.263
Last update unknown.
Many thanks.
krfstudd
Hi @bobpullen ,
Could I also get the firmware update please.
5Ghz Network is constantly dropping, 2.4Ghz and Ethernet are still fine. All devices lose connection regardless of distance. Blue light is still on, but cannot connect to the network. Resetting the router always brings it back, but it quickly goes again
Tried Un-splitting and re-splitting the Channels, resetting the wifi, factory resetting the router, changing the channels. all have not managed to help so far.
Then the 2.4Ghz network is far slower than the 5Ghz network. (20Mbps instead of the 70-75Mbps on the 5Ghz)
Any help would be fantastic.
Software Version 4.7.5.1.83.8.263, Last Update 'Unknown'
Serial Number: +081441+NQ51607629
Router Plusnet Hub One.
Many Thanks,
Kynie
bobpullen
Fixes: 330
@NicDB @keithscarfe @DaveH76 & @krfstudd - I've pushed the update your way. You'll need to restart your respective devices to apply it.
@srgrice - I'm having difficulty communicating with your hub so I've scheduled an upgrade to take place the next time it calls home. If it's currently in use, then try restarting it and waiting a few days for the update to come through.
MaiB
@bobpullen   An update on the latest firmware update as requested...
Unfortunately I am still getting drop outs daily.  The causes on the W10 trouble shooter continue to show as "Wifi does not have a valid IP configuration" and mainly "Defaut Gateway not available".  One such incident occurred at 13.01 and shows on the Event log, as previous events have also similarly shown.
13:02:00, 21 Oct. BLOCKED 2 more packets (because of ICMP replay)
13:01:58, 21 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 31.125.32.178-​>5.62.42.108 on ppp3)
13:01:57, 21 Oct. BLOCKED 4 more packets (because of ICMP replay)
13:01:55, 21 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 31.125.32.178-​>34.251.27.48 on ppp3)
13:01:54, 21 Oct. BLOCKED 2 more packets (because of ICMP replay)
13:01:53, 21 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 31.125.32.178-​>34.249.110.48 on ppp3)
13:01:44, 21 Oct. IN: BLOCK [16] Remote administration (TCP [67.205.170.72]:59053-​>[31.125.32.178]:443 on ppp3)
13:01:21, 21 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 31.125.32.178-​>212.58.237.254 on ppp3)
