How to change Hub to Bt hub?
- My Router
- How to change Hub to Bt hub?
07-09-2020 9:08 PM
I can’t find away to fix this and I’m sure it’s this rubbish hub. I have never had to change them before, had sky and bt, but Plusnet is not great.
How in very simple terms can i swap and use my old bt5 hub? I just want to try something as this is driving me mad. I can’t find a simple step by step fix.
If anyone can help please do so as this is like dial up at times.
Re: How to change Hub to Bt hub?
07-09-2020 9:17 PM
Moderators Note
This topic has been moved from Fibre to My Router
07-09-2020 9:43 PM
It is quire simple, just need to enter your username and password. Not sure which BT Hub you have, but look at the thread aboe yours, link here.
08-09-2020 1:52 AM
08-09-2020 8:44 AM
The Plusnet Hub 1 is a rebadged BT Home Hub 5A so using your BT hub may not help you at all. If you want a better router the BT Home Hub 6 Business version is recommended by other Plusnet customers.
08-09-2020 9:18 AM
Whilst the Hub One hardware is the same as the HH5a the firmware is different so it's worth trying.To do this you must first unplug the Home Hub 5 DSL cable. Then enter your Plusnet user name followed by @plusdsl.net and your account password. Save this and only then plug in the DSL cable.
14-09-2020 2:33 PM
- My Router
