Help with setting up security cameras/static IP
Fixes: 577
Re: Help with setting up security cameras/static IP
@salcalvert so have another think about this overnight...
The port forwarding seems to be working , since test-netconnection succeeds.
The dvr can be accessed locally using its private (192...) IP
So logically, if we assume external traffic is getting TO the dvr, then its the response that's getting lost. If so, then it would point to the gateway IP being wrong (or the DVR ARP cache?). Having an incorrect gateway wont affect local traffic but it will stop outbound external traffic.
So @salcalvert can we try setting the DVR to dynamic IP, that will force it to get gateway & network mask automatically.
Probably best to restart the DVR after that and check that the Connection page now shows a different IP.
Check that you can still connect to the DVR locally using that IP.
Then go to the Hub 2 ,
Go to the Advanced/My Network page.
Select the DVR device.
Select Always Use this IP Address and Save.
No go to the port forward page and change the forwarding rules to use the new internal IP allocated to the DVR
Now try accessing the DVR externally using your public IP 212... or <accountname>.plus.com
salcalvert
Many thanks, not working from home today so can’t access the equipment but will try this tonight.
salcalvert
@MisterW
"can we try setting the DVR to dynamic IP, that will force it to get gateway & network mask automatically."
Done. the gateway and network mask have now changed to something different than what my router states them to be and I am unable to edit them.  I had previously made sure these matched what my router homepage told me they were.
"Probably best to restart the DVR after that and check that the Connection page now shows a different IP."
Done.  But the internal IP of the DVR did not change.
"Check that you can still connect to the DVR locally using that IP."
Yes this worked.
"Then go to the Hub 2 , Go to the Advanced/My Network page. Select the DVR device. Select Always Use this IP Address and Save."
I didnt need to select this it was already on.
"No go to the port forward page and change the forwarding rules to use the new internal IP allocated to the DVR"
IP hadnt changed so this didnt need editing. Have rechecked and ports are open.
"Now try accessing the DVR externally using your public IP 212... or <accountname>.plus.com"
Sorry, still wont connect.
Fixes: 577
I would expect them to be Gateway - 192.168.1.254 Netmask 255.255.255.0 , is that what they are ?
So is the IP still 192.168.1.200 ?
That suprises my somewhat , since I thought .200 is outside the DHCP range of .64 to .199 ?
Oh dear! back to the drawing board...
salcalvert
@MisterW I would expect them to be Gateway - 192.168.1.254 Netmask 255.255.255.0 , is that what they are ?
My mistake, gateway yes, netmask is that but with a .7 at the end
yes.
Should I change everything back?  Or buy a new TPLink router??  haha
Fixes: 146
@MisterW
Hub Two DHCP range is .64 to .253.
@salcalvert
The app you have loaded on your smart phone, does it work when you connect to your home WiFi?
Maybe set the smart phone up as a mobile data hotspot and try using a PC?
Fixes: 577
@Dan_the_Van Thanks, I wasn't sure what the default range was. That explains why the DVR is still at 200. Even though the DVR was set to static , the Hub had previously seen it connected and marked it as fixed.
Now that's not right!. Not sure how its got that as a netmask ? should definitely be .0 . @Dan_the_Van is the netmask changeable on the Hub 2 , I didn't think so ? I assume the setting is on the LAN details page somewhere ?
Fixes: 146
@MisterW
Not that I have changed the mask, but I believe it can be, someone here complained that a /28 (I think) didn't work.
Network settings
I'm using 192.168.10.0/24
Fixes: 577
@salcalvert can you check that the netmask is set correctly on the Hub 2 network page as show above , it should be 255.255.255.0
Just trying to understand the consequences if it was .7 ?
Fixes: 577
255.255.255.7 isn't a valid netmask
salcalvert
Sorry guys, I've misinformed you, my mistake for doing this in a rush and the DVR is in another room to where I can log into the router. I mistyped. working from home today so much more opportunity.
netmask is 255.255.255.0 on both the router and the DVR.
Its the gateway that doesnt match. The DVR changed gateway to 255.255.255.127 when we moved the settings from Static IP to Dynamic IP yesterday and cannot now be edited by me.  Router says my gateway is 195.166.130.254.  (I had previously matched these gateway settings in DVR and router)
Incidentally just noticed my router says I have a "Broadband IP address" which is the 212. string we have been using as the static IP, but I also have a "Broadband primary DNS" and a "Broadband secondary DNS" which are both different.
Champnet
Fixes: 21
A DNS server is like a phone book, give it a name it will return a number. One is neccessary - two is better than one...
Fixes: 577
@salcalvert well , they're both wrong!
The gateway you see on the router 195.166.130.254 is the router gateway to the internet. The gateway the DVR should have is the gateway device to get from the private 192.168.1.x subnet to the internet, it should be the router address 192.168.1.254.
Where the router is getting 255.255.255.127 from , I have no idea.
I suggest we switch back to static IP on the DVR with the following settings
IP 192.168.1.200
Gateway 192.168.1.254
Subnet mask 255.255.255.0
DNS 192.168.1.254
salcalvert
IP 192.168.1.200
DNS 192.168.1.254
Confirmed this is done and restarted the DVR.  These were the settings we had before the switch yesterday.
Fixes: 577
but you said above
Does local access to the DVR still work ?
and I guess remote access doesn't ?
