HUB One not playing SSH with Raspberry Pi over PuTTY
only1symo
Having trouble using my pi3 remotely when not at home.  Set up the Hub One with the pi and SSH server as recognised applications/devices and with a static IP on the router, but still can't log when in Germany using PuTTY.
Helps?
6 REPLIES 6
markhawkin
Fixes: 12
Re: HUB One not playing SSH with Raspberry Pi over PuTTY
@only1symo
Apologies for blindingly obvious suggestions but:
You have a static IP address or some other way of knowing the IP address of your Hub One?
Has this ever worked before? I assume you tested it from "outside" your network before you went abroad.
I tried port forwarding on the Hub One to another router (inside) and couldn't make it work.
bobpullen
Fixes: 316
I doubt the Pi will respond to ping without you putting it in the router's DMZ and fiddling with the Pi's iptables (in fact, could the latter be what's blocking your SSH attempts?)
From first hand experience I know that what you're trying to do it definitely achievable.
markhawkin
Fixes: 12
 @bobpullen
Yes, I came to that conclusion very quickly and edited the post!
I can't immediately think of a way of confirming how far the connection gets as the Hub One discards ping as far as I know.
bobpullen
Fixes: 316
How long are you away for? If I get a spare minute, I can open up ping on the Hub to make sure you're able to get that far.
markhawkin
Fixes: 12
Also, this all feels very insecure. Personally I would use a router that supports an inward VPN connection.
@bobpullen
How did you make a Pi on a Hub One work?
bobpullen
Fixes: 316
Forwarded the port and allowed external SSH connectivity with an iptable rule. If you're planning on leaving the Pi open to the Internet, I'd suggest looking at something like fail2ban too.
