Getting router firmware upgrade.
trebor
I just reset my router and on reboot it offered a firmware upgrade. I declined it as I had not recently backed up my settings.
I have now backed up my settings but on reset it does not offer me the firmware upgrade again.
How do I get the firmware upgrade for my plusnet hub one?
Account is sadler on force9.
2 REPLIES 2
bobpullen
Fixes: 306
Re: Getting router firmware upgrade.
You're already running the latest production firmware - 4.7.5.1.83.8.263.
I'm not sure what you're referring to with the firmware upgrade prompt though? That's not how things work. You wouldn't see any notification that a firmware was being offered without scrutinising the router logs Huh
trebor
Logging into the router after resting it offered an upgrade to the firmware something like a there is a firmware upgrade available for your router. Upgrading will clear all your user settings with a tick box to accept or decline it.
