Draytek vigor 2862 settings problem
sagerox
Hi I have the above router. When I connect it to the plusnet line i get a site not found error when i try to browse  the internet.I When I run windows diagnostics on the device adaptor it comes up with a DHCP error. What settings do I need in the router?
The online status within the router shows that it is connected and passing data.
The rouer works when I connect it to a BT line and put in the BT broadband username and password
3 REPLIES 3
Fixes: 356
Re: Draytek vigor 2862 settings problem
The plusnet settings are here https://www.plus.net/help/broadband/broadband-connection-settings/
tinytaco
Fixes: 29
Hi there @sagerox if you're having issues with the 3rd party router still, we'd advise you to go back to the Plusnet one to ensure it isn't a router issue.
 Noor
markhawkin
Fixes: 11
@sagerox
I use a very similar Draytek 2860 on Plusnet and it's fine.
There are good instructions here:
https://www.draytek.co.uk/support/guides/vigor-2860-vdsl-setup
Just use your Plusnet credentials In "ISP Access Setup"
