Connection problem when using my phone and laptop
JodyI
Im hoping someone can help me out here. Last week I got a new phone the sony xperia xa ultra and since then when both my phone and laptop is using the wifi my latency jumps to over 3000ms and when I disconnect my phone and only use my laptop my latency goes back down to 40ms, I never had this problem when using my old phone.
Any help would be much appreciated.
4 REPLIES 4
bill888
Champion
Fixes: 38
Re: Connection problem when using my phone and laptop
What is the model number of the wifi router?
How old is your laptop ?
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
JodyI
Hey bill888.
The model is router 2704N plusnet and it's a sagemcom.
My laptop is only 2 months old.
Fixes: 397
Hi, Sounds like it could be a similar problem to this thread https://community.plus.net/t5/Broadband/just-moved-to-plus-net-and-now-terrible-speeds-and-high/td-p... . Likely your phone is set to backup to google and is saturating the upstream bandwidth.
Chris
Legend
Fixes: 169
Can you PM me your username so I can take a look at what's going on?
