Checking UDP Ports are open
Fotoman
I am sorting a problem with my security cameras and the manufacturer's have asked me to turn on all the UDP ports from 1-65535 on my router as the cameras use random UDP ports for remote connection.
Can some kind person please point me to where I would find this setting within my Router settings?  I have a Hub Two Router.
Thank you.
14 REPLIES 14
Fixes: 579
Re: Checking UDP Ports are open
@Fotoman are they taliking about outgoing connections or incoming ?
All outgoing ports are open by default. Opening all ports for incoming connections sounds very strange...
Fotoman
They don't say.  I am presuming Outgoing as the camera problem is with me accessing my security cameras when away from my home network.
Fixes: 147
@Fotoman
Some more details of your CCTV system would be helpful.
Are you connecting to an individual camera, many camera's or a NVR/DVR
Fixes: 382
@Fotoman As @MisterW says, all outgoing ports are open by default. You really need to get your camera manufacturer to be a little more specific.
Fotoman
I've got two cameras (Reolink Cameras) but I cannot access them when away from home.  If all ports are open by default, then presumably, it's another fault outside of the home network and more to do with the camera set up.
Jon
Fixes: 4
According to How to Forward Ports on Router Interface for Reolink Products the ports needed forwarding are 9000, 80, and 1935. You should be able to forward these, along with the protocol (TCP or UDP, or both), to whichever host within your network is needed.
The ports aren't being blocked at the ISP level, so should be a case of just adding the rules above to allow remote access.
Thanks Smiley
 Jon
 Plusnet Infrastructure Operations Professional
7up
Fixes: 20
So that means incoming ports - which is what you configure in your router.
You connect to the cameras in your network by connecting to your public IP address (router) which then forwards your traffic to the device which then responds to you using that connection. That is known as an incoming connection (it's incoming to your network).
However as pointed out elsewhere, opening up every single port on your router (or in effect, turning off your firewall) is very odd and not normal behaviour for any application to need.
Champnet
Fixes: 21
I’ve 4 Reolinks in the house which I can access remotely. I’ll check tomorrow how it’s setup,  I do know I have not opened any ports on the router…
Champnet
Fixes: 21
I've had a quick look but I must have set this up ages ago...........
Looks like I have a Reolink Account and all cameras are registered to the account. Windows desktop, iPad & iPhone use the Reolink app. so an educated guess:  Camera's connect to Reolink servers, external users also connect to the Reolink servers, connection between camera and user made. Can't prove this but I'll try to find a way to monitor outgoing camera traffic
Champnet
Fixes: 21
Just to confirm there is a permanent connection between cameras and remote servers
Fotoman
Thank you all for your quick responses.  The situation has now been resolved. It would appear that I met with the 'work experience' person from the manufacturer who was directing me to the wrong menus.
7up
Fixes: 20
That's quite common as outgoing connections are not often blocked by a firewall and so if the camera makes an outbound request to a server that is not blocking incoming connections and the client so also makes an outbound connection to that same server they can both relay data to each other without the worry of firewalls and ports.
Champnet
Fixes: 21
@7up  Agreed, but these connections are permanent which is not ideal.
@Fotoman Care to explain the solution ?
7up
Fixes: 20
Depends on your perspective of things. For me that would be convenient - instant access +/- a second or two. It's not like hackers are going to be able to send commands to your other computers via that device - ok the owners of the server might be able to LOL but they'll want to keep that to themselves rather than share it about.
