Changing Router
grundy2
Changing Router
I am thinking about changing the default router to one of these
https://amzn.eu/d/ib0o8Rr
Or
https://amzn.eu/d/ddS0PR1
Can I get some help on if these would be compatible, unsure if they are.
15 REPLIES 15
mystreet1
Re: Changing Router
They are only suitable for FTTP, connect to the ONT, not FTTC.
As long as you can set the VLAN to 0 or blank and add your PN credentials they should work
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
Fixes: 93
Re: Changing Router
Why would you think that?
The ONT can be seen as a modem, so provided with part Fibre (FTTC/SoGEA) you use a modem with the routers WAN setup for PPPoE it will work.
I have used the TP-Link AX53 successfully with FTTC using Hub Two in bridge mode
Edit added PPPoE config details
PPPoE account details
Broadband username or login name	yourusername@plusdsl.net
Connection type or encapsulation	PPPoE Always On
Password	The password you use to log in to the My Account
mystreet1
Re: Changing Router
Because the OP stated that they would be changing the default router.
They have not stated what service they are on so I assumed FTTP as these do not have a ASDL socket
Fixes: 93
Re: Changing Router
I agree the OP did not state what type of router,  for some router is a generic term so it could mean a router only device or combined modem/router.
I was filling in the gaps of your post.
grundy2
Re: Changing Router
To further clarify this
The hub 2 has a broadband port, phone port and 4 1 Gig ethernet ports
The broadband port, phone port are unused.
Legend
Fixes: 290
Re: Changing Router
To clarify further, are you on an FTTP or FTTC  connection?
grundy2
Re: Changing Router
I believe fttp, as I have the Full Fibre 500 package.
Fixes: 93
Re: Changing Router
In that case either of your choices will work, depends on how much you want to spend.
I've previously posted the necessary setting.
grundy2
Re: Changing Router
Will update once this arrives. Thanks all for you help.
jaydee001
Re: Changing Router
I have the BE550 and can honestly say it's a great piece of kit - I have FTTP 900, running Ethernet with my gaming pc at 2.5GB (yes I know plusnet don't offer above gig... yet hopefully 🤞) and a few devices running on Wi-Fi 7 alongside 6E - Never experienced any slowdowns and the router hasn't given me any issues since I purchased it
Deffo a steal at £200 - purchased mine a few months ago for £300 but can't complain at that price especially for what you get with it.
grundy2
Re: Changing Router
If you can set it to 0 I don't know how. Every time I try this appears.
Enter a value between 2 and 4094.
Fixes: 455
Re: Changing Router
@grundy2 is there a separate option to 'disable' VLAN ID ?
grundy2
Re: Changing Router
No there is not.
I can either enable or disable IPTV/VLAN but that is it. If I emable it I cannot disable the VLAN ID
Fixes: 455
Re: Changing Router
In that case I suggest you disable IPTV/VLAN
