Extender access from Hub Two
Brian5
I have a Hub Two, and I am using a D-Link AX1500 range extender. Is there any way of accessing the extender via the Hub Two Manager?
4 REPLIES 4
Fixes: 388
Re: Extender access from Hub Two
No. Is there a D-Link app?
Brian5
Yes, the Eagle PRO AI App. But I can't persuade it to see the extender. When I installed the extender, I just used the option to hold it close to the router till it was connected.
Fixes: 388
As I have never used an extender, I don't think I can offer any further help, sorry. Hopefully, someone else can assist.
I would expect in most cases it will be possible to connect to the wireless extenders IP Address using a browser.
On the Hub two look in >Home >My Devices >Wireless Connection Devices
Hopefully here you will see the DHCP allocated IP Address for the D-Link device.
Another option would be to factory reset the D-Link device and start a fresh
HTH.
