Change Router IP address
GDshub2
I know there is a way of changing IP address of the Hub 2 router.
My question is:
Does changing its IP address have disadvantages and if so what are they vs. any advantages please?
10 REPLIES 10
Fixes: 384
Re: Change Router IP address
The first question I have is - why would you want to change it?
GDshub2
I suppose I ought to have added the reason:
I’m changing the SSID too, so thought to change IP address of router at the same time.
Fixes: 384
But why? I can kind of understand changing the SSID, but you gain nothing by altering the Hubs IP.
GDshub2
Thanks John
So, zero gain? Nada?!
If so, thanks for the clarification!
Cheers 👍
Fixes: 384
No problem, and as you say, zero gain.
A disadvantage I could foresee is if you MANUALLY changed the 'gateway' address on any of your network connected devices (such as printers),  if in the future you ever had to "Factory Reset" your Plusnet Hub then the IP address would revert back to the default - so your manually configured LAN devices would be unreachable until you re-changed the router's LAN IP to the alternative address that you were using.
If your entire home network uses DHCP to get the device addresses, then it shouldn't make much difference
Fixes: 384
Meant to mention that slight disadvantage and forgot - the same will apply to the SSID change as well.
GDshub2
Excellent point!
Thank you, I get it 👍
I guess:
Just because you ‘can’ doesn’t mean you ‘should’!
Fixes: 246
The only practical reason to want to change the IP address of a router is to add it to a network as a repurposed WAP (with DHCP switched off) so as to not clash with the primary router’s DHCP configuration / operation.
GDshub2
Thank you!
I’m not planning on creating such, so apart from changing my SSID, the router IP address will stay as is.
Cheers to everyone who replied 👍
