Can't access hub manager
- My Router
- Re: Can't access hub manager
05-09-2026 10:23 PM
Hi - I'm a new Plusnet customer and I'm trying to load the hub manager page but it keeps timing out.
I've entered http://192.168.1.254/ or 192.168.1.254 into the address page and I get this message:
Plusnet Hub Two Manager
The connection was reset.
05-09-2026 11:54 PM
This is to do with the firmware update and it is pants 😒
I think there is a link called Advanced and then proceed (or similar wording). It will try to warn you about an unsafe connection, but all will be good. You have to go through this every couple of weeks. A real ball ache.
Mark
06-09-2026 8:41 AM - edited 06-09-2026 8:42 AM
Did you try HTTPS direct to the Hub : https://192.168.1.254
You are still going to be faced with the browser warnings for a Self Signed Certificate,
I am afraid we are stuck with this very ugly logon process but it is safe to proceed for a Hub.
06-09-2026 11:13 PM
thanks both, no I still just get the error message 'This site can’t be reached' when I enter https://192.168.1.254 and click on 'switch to HTTPS'
I'll try via my wife's laptop and see if it does anything different.
thanks again
07-09-2026 7:25 AM
If that is a work laptop, make sure the VPN is OFF when trying to access the router.
2 weeks ago
Hey, did you fix this?
No matter what i try the page wont load for me. Tried the https one too. I don't get the warning pop up either to continue, the page just keeps timing out everytime.
a week ago
Thursday - last edited Thursday
No ryanjafc I've tried every device in the house including my daughter's Chromebook, attempted it using laptops with VPNs both on and off, but the page just times out/shows as unavailable every time. Has anyone tried calling Plusnet customer services?
4 hours ago
@JamesHP & @rjuk96 - imagine you have but have both of you tried powering the hub off/back on to see if that helps?
- Do you have a device you can try Ethernet cabling to the hub to see if that makes any difference?
- Is there anything 'non-default' about your setups? i.e. have you previously changed any other settings from defaults?
- Do you have any other networking equipment on your LAN like third party extenders/Powerline adapters etc?
- Are you doing anything that routinely 'interrogates' (accesses) the Hub Manager e.g. monitoring software?
- Can you ping the router IP at 192.168.1.254 from a connected device when the problem occurs?
If either of you want to get your hands dirty, then there might be some clues if you try accessing the Hub Manager with your Browser inspection tools open. The network log there could indicate what's going on (perhaps AI could cast its eyes over things?)
@rjuk96 - your case is particularly suspicious if exactly the same symptoms were witnessed when using a BT hub 🤔
- My Router
