Can't access hub manager
JamesHP
Hi - I'm a new Plusnet customer and I'm trying to load the hub manager page but it keeps timing out.
I've entered http://192.168.1.254/ or 192.168.1.254 into the address page and I get this message:
Plusnet Hub Two Manager
Secure Connection Required
Access to the Hub Manager now requires a secure HTTPS connection.
Switch to HTTPS
⚠ You might see a browser certificate warning - what do I do?
But when I click on 'switch to HTTPS' it doesn't load a new page and eventually says:
This site can’t be reached
The connection was reset.
etc
I'm using Google Chrome, the router seems to be working fine but I want to access parental controls.
I've tried over a few days but always with the same outcome.
thanks
7 REPLIES 7
Marksfish
All Star
Fixes: 5
Re: Can't access hub manager
This is to do with the firmware update and it is pants 😒
I think there is a link called Advanced and then proceed (or similar wording). It will try to warn you about an unsafe connection, but all will be good. You have to go through this every couple of weeks. A real ball ache.
Mark
PhilipHeyes
Seasoned Champion
Fixes: 29
Did you try HTTPS direct to the Hub :   https://192.168.1.254
You are still going to be faced with the browser warnings for a Self Signed Certificate,
I am afraid we are stuck with this very ugly logon process but it is safe to proceed for a Hub.
JamesHP
thanks both, no I still just get the error message 'This site can’t be reached' when I enter https://192.168.1.254 and click on 'switch to HTTPS'
I'll try via my wife's laptop and see if it does anything different.
thanks again
PhilipHeyes
Seasoned Champion
Fixes: 29
If that is a work laptop, make sure the VPN is OFF when trying to access the router.
ryanjafc
Hey, did you fix this?
No matter what i try the page wont load for me. Tried the https one too. I don't get the warning pop up either to continue, the page just keeps timing out everytime.
rjuk96
I'm having the same problem. I can't access any of the router's advanced settings at all to change the wifi name/password etc. I had the same issue with my BT router before I switched so there is clearly a glitch with the router management page. This is a seperate issue to the security/HTTPS issue. This issue makes navigating the router management page very laggy until it just times out every time I try to enter the admin password. It then wont let me access the router management page again until I turn the router off for 2 mins. I've done a factory reset which hasn't helped. It's incredibly frustrating.
JamesHP
No ryanjafc I've tried every device in the house including my daughter's Chromebook, attempted it using laptops with VPNs both on and off, but the page just times out/shows as unavailable every time. Has anyone tried calling Plusnet customer services?
